It is currently Mon Apr 06, 2026 2:53 am
PostPosted: Thu Jun 21, 2007 7:16 am
I am trying to figure out what size 15" tire to run on the back of my truck and wanted to ask if a few could post pictures of the rear tires on their Chevy Luv along with the size of the tire so I can make up my mind. I am thinking about a wider tire than the front but not sure. Thanks!
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
PostPosted: Thu Jun 21, 2007 8:25 am
Here ya go... :lol:
PostPosted: Thu Jun 21, 2007 10:51 am
18.50 inch's wide works for me. 15X15 rear rim with 31 X 18.5 X 15 Hoosier tires.
Number two has 245 60 14 tires on 14X8" rims.
If you need more info from me just ask.
PostPosted: Thu Jun 21, 2007 1:13 pm
165R15 front on 15 x 6
255/60/15 rear on 15 x 8 I have had a 28 x 9 x 15 slick on it .
Factory frame with 9 " ford .
PostPosted: Fri Jun 22, 2007 6:06 am
31-18.5 on 15-14 Centerlines
PostPosted: Fri Jun 22, 2007 11:19 am
Weld Draglites 15 x 8, 5.5 backspacing
Mickey Thompson Street ETs 26 x 10.5
Stock width S10 rear end.
Stock Luv spring setup + 2" lowering blocks
PostPosted: Fri Jun 22, 2007 11:35 am
Hyper, you run tubes in your M/T's. I have 11:50's I am putting on.
PostPosted: Sat Jun 23, 2007 12:18 am
nice :lol:
PostPosted: Sun Jul 08, 2007 10:22 pm
I have 295/50/15's on mine,frame is narrowed 5 inches from stock.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Wed Jul 11, 2007 9:38 am
Japanese Redneck
I've tried a lot of different combos under my truck and if you're talking about stock frame rails and tires completely tucked under, I think this is about it.
295/60-15 radials (if you can find them) but most likely 275/60-15 radials are more common... OR
28x10.5 MT Street Drag...OR
28x11.5 MT ET Street
This would be on a 15x8 Weld Wheel for example and depending on what rear end you are using, a 4.5 to 5.5 rear space.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Jul 11, 2007 9:05 pm
I found a place out here in Bellflower that can make and or rework wheels. They supply all the Long Beach and Pomona swap meet sellers.
My buddy has a 65 Chevelle and with the stock rally wheels , (15") he still had 2 1/2 " of space for tire on the inside. So he had a set of rallies reworked with a different off set to tuck the wheel under the car and now he can put on a wider tire.
He got 15 X 6 rally wheels, new with a special off set ( I don't know the measurement) for $80.
PostPosted: Wed Jul 11, 2007 11:16 pm
I'm on 10" wheels with 4" BS and drum brakes
[color=#FF8000]
PostPosted: Sat Jul 14, 2007 5:20 pm
Here's my ugly butt:
Stock S10 rear with 15X10 Centerlines and either 295 or 305 50/15's. They stick out a couple inches, but ill get the frame and rear end narrowed one of these days.
1975 LUV with a caddy 500ci, 12.5-1 comp, 850CFM holley sucking E85 through 110 jets and torquing the hell out of a TH400. Currently @ 6mpg
Bowties may be for little boys, but ponies are DEFINATLY for little girls....
