It is currently Thu Apr 09, 2026 5:26 pm
PostPosted: Thu Apr 26, 2007 12:56 pm
Just bought a 79 chevy luv off a friend and i have to say its one fun truck.
My problem is i ordered an electronic distributor just to find out that it doesnt directly trigger the coil. If only i found this site earlier to see all the different options i had instead of taking a risk and ordering the distributor in.
Is there a way to make this distributor work with out buying a control module? Can the msd 5 or 6a be triggered by it?
A-1 CARDONE Part # 31628
If i have no other option I may see if i can return it and go with a PerTronix Ignition BTW is the PerTronix Ignition just a part that drops in place of the points?
Thanks
 Post subject: .
PostPosted: Thu Apr 26, 2007 1:03 pm
"If i have no other option I may see if i can return it and go with a PerTronix Ignition BTW is the PerTronix Ignition just a part that drops in place of the points?"
Pretty much
Not sure as to which dizzy you have, but my 79 currently has MSD 5200 with Blaster coil, stock Nippondenso dizzy with Pertonix Ignitor electronic ignition module replacing points etc...runs like a scalded dog.
There are several threads with info on elec conversions, check out the general section. couple of recent ones there.
Welcome to the site by the way :)[/quote]
FIAA: Color Guard
 Post subject: .
PostPosted: Thu Apr 26, 2007 1:09 pm
Here's a good example of a typical Pertronix install, not by me, I was to busy and lazy to document mine.
http://www.ttalk.info/Tech/Pertronix_Into_TD.html
FIAA: Color Guard
PostPosted: Thu Apr 26, 2007 1:24 pm
Wow thanks for the quick reply.
Looks like the best way to go my points distributor has very little wear only up and down slack on the shaft but the new one seems to have the same amount of play.
 Post subject: .
PostPosted: Thu Apr 26, 2007 1:26 pm
If you do go the Pertronix route, give em a call with you distributor model info, they will know which kit or module-magnet combo would be best.
FIAA: Color Guard
PostPosted: Thu Apr 26, 2007 3:22 pm
Not knocking the pertronix option, but if you can find a distributor, coil, and ignitor module from an '82 Isuzu pup, '82 chevy luv, or '82 isuzu imark with a 1.8, then you will be able to make a very simple conversion and still stay very close to a stock setup.
I picked all of my parts up for converting my '79 Luv over to electronic ignition for less than $100.00 from a local junkyard...but I had to go out and look in all of the yards myself, because none of the yards I talked to knew what I was talking about, had any clue whether they actually had one or not, and had zero desire to get up off of their butts and go check for me. (Imagine that...lol) And when I tried to talk to them about what I was trying to do, and whether or not their parts would work, I might as well have been speaking Klingon...lol
I noticed that http://car-part.com/ lists a few of the distributors and the coil/ignition modules for that particular year, but I don't know how accurate their info is, so maybe that will help with your search.
But in the end, it's your wallet and your choice which way you want to go.
Good luck and happy hunting!
PostPosted: Sun Apr 29, 2007 1:47 pm
They allowed me to return the distributor. (the should have anyways i do enough business with them)
I think ill go with pertronix just for the simple fact that they have a store in my area and its a simple setup. Besides that my current points distributor has no noticable wear on it.
Ill just have to wait till monday to give them a call. I need a performance coil anyways so i may also try one of there hotter coils.
PostPosted: Wed Jun 13, 2007 10:56 pm
Took me long enough to reply back.
The part they gave me was the wrong one PN 1144a
So what fits a 79 luv? Where would the numbers be on the stock distributor?
Ive taken the distributorr out and cant find any numbers on it to order a diff pertronix ignitor.
Thanks
 Post subject: .
PostPosted: Wed Jun 13, 2007 11:03 pm
Mine has stock distributer.
Nippondenso
8942065420
029100-3281
This is the kit I got, http://pertronix.carshopinc.com/product ... id/79/1741 looking back, I got a little click happy when ordering... out of desperation to get away form the points nightmare.
Ended up having to make my own plate for the module and a mod to the inside of the magnet(ring) that goes on the dizzy shaft. And had to ditch the vac advance. I have used it with and without MSD 5200.
FIAA: Color Guard
PostPosted: Mon Jun 18, 2007 3:48 pm
sleeps at LUVTruck.com
"Mine has stock distributer.
Nippondenso
8942065420
029100-3281
Ended up having to make my own plate for the module and a mod to the inside of the magnet(ring) that goes on the dizzy shaft. And had to ditch the vac advance. I have used it with and without MSD 5200."
So is there an electronic ignition setup that fits the stock distributor on a 79' without having to modify anything?
 Post subject: .
PostPosted: Mon Jun 18, 2007 4:04 pm
From the convo I had with them, they can build a kit. Would probably want you to ship your distributor.
BTW, am back to using my vac advance now.
FIAA: Color Guard
PostPosted: Tue Jun 19, 2007 10:18 am
is there any kit you can buy that you can have the truck still running while they are sending you the kit :?:
 Post subject: .
PostPosted: Tue Jun 19, 2007 10:51 am
The 1741 http://pertronix.carshopinc.com/product ... id/79/1741
kit will work with some minor modification, realy not that hard to do. If you have a rotozip or Dremel to modify the baseplate, your 3/4 of the way there. Another option I was prepared to resort to, would be removing the module from it's plate and mounting it directly on the distributer plate, would only require drilling 2 holes. The plate is easy to remove from the dizzy, no need to pull the entire thing.
Would be happy to send pics etc.
FIAA: Color Guard
PostPosted: Fri Aug 10, 2007 6:18 pm
Another few months pass and i finally got back around to posting back.
The 3 ohm flamethrower coil works better then the super stock accel coil i had previously. Punchier low end and and smoother high end over the accel.
For the distributor number listed in earlier posts they did have a part that did fit it. The style requires no gap adjustment and mearly requires a little sand paper on the magnetic ring to get it to fit properly.
This did fit my 79 the part numbers are on the boxes are:
16430 - module
an
18433 - magnet ring
Everything is functional still including the vaccuum advance
 Post subject: .
PostPosted: Sat Aug 11, 2007 6:31 pm
Excellent news 101... nice to hear they now have the parts for a 79. Adding those numbers to my watch list in the event my "custom fit" set fails.
Are you having to use ballast resistor with their coil?
FIAA: Color Guard
PostPosted: Sat Aug 11, 2007 10:58 pm
What the heck is that?
 Post subject: .
PostPosted: Sun Aug 12, 2007 5:33 am
Flamethrower... brand of coil made by Pertronix.
FIAA: Color Guard
PostPosted: Sun Aug 12, 2007 8:27 pm
So how much does that bad boy cost?
 Post subject: .
PostPosted: Sun Aug 12, 2007 8:28 pm
Seen them on Ebay for $30-45
FIAA: Color Guard
PostPosted: Sun Aug 12, 2007 8:41 pm
I haven't used the ballast resistor in a week and so far no problems.
I followed what they said on there site (link below)and was just under the 4 amp mark using the 3 ohm coil.
http://www.pertronix.com/tech_support/troubleshooting.htm#line2
Users browsing this forum: No registered users and 86 guests
