It is currently Sun Jun 28, 2026 12:32 am
Post new topic Reply to topic  [ 246 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 13  Next
PostPosted: Tue Jun 12, 2007 12:14 am
Noticed water dripping between the cylinder wall and the #4 piston when I pulled thy pan off. When I rotated the piston up ( it was at the bottom of the stroke) water ran out the header. The heads were pressure checked before using ( no probs on the motor they were on) heads o-ringed, reciever grooved block, head studs sealed, solid copper head gaskets. I'm guessing a cracked cylinder.
PostPosted: Tue Jun 12, 2007 5:48 pm
that sucks :evil:
PostPosted: Wed Jun 13, 2007 12:06 pm
Thay is the pits . Keep use posted .
PostPosted: Sun Jun 17, 2007 11:17 am
Did the teardown, looks like the problem is in the head, which is an easy fix (aluminum). Everything else looked GOOD, so I hope to have it back together in a couple of weeks. :lol:
PostPosted: Sun Jun 17, 2007 2:51 pm
While it is out any chance of finding any more power?
PostPosted: Sun Jun 17, 2007 7:01 pm
Too broke :( I've got 18 degree pistons in it with an eye towards upgrading in the future though. Got a spare set of SB 2 Yates C3's lying around in the round round cast offs Luvr8? :lol:
PostPosted: Sun Jun 17, 2007 8:50 pm
We are Brodax -10 people.
PostPosted: Fri Jun 22, 2007 3:14 am
:? Well the head passed the pressure test and also wasn't warped. Block looks perfect. The saga continues.
PostPosted: Wed Jul 11, 2007 10:07 am
It is amazing how long it takes for the local distributor to get a set of copper head gaskets, the &*$$*$#...
PostPosted: Mon Jul 16, 2007 8:44 pm
Finally got my new gaskets, just gotta coordinate a build and install time with my bud's. Gotta work around the go cart racin'. :lol:
PostPosted: Sat Oct 20, 2007 11:16 am
I cleaned out the garage around the truck with an eye towards finishing the install...
PostPosted: Fri Nov 09, 2007 11:39 pm
Well, I mostly finished the install, just need a distributor now to fire it up, but when I tried to push it out of the garage, the rear end kept locking up. I drove it in the garage...
Pic of the engine bay
PostPosted: Wed Nov 21, 2007 10:52 pm
Found the rear end problem, I have threaded wheel studs and one of them backed off when i installed the new tires and remounted the wheels.
PostPosted: Thu Nov 22, 2007 7:19 pm
Looks like it's going back together . That's great .
PostPosted: Sat Dec 08, 2007 1:32 am
Score! I was talking to a friend about the dizzy situation and he walked over to his parts stash in his shop and gave me a crank trigger setup. Now to figure out how to wire it... :lol:
 Post subject: Re: truck pic's
PostPosted: Sun Mar 23, 2008 12:30 am
Update! I finally have it mostly back together. All I need now is to dial in the crank trigger setup. The guy I got the stuff from wants me to bring it up to him to set it up, so I'm just waiting for his schedule to clear. I am adding a low mount alternator setup due to all the added electronics. I also need to replace the valve cover gaskets. I got some great deals from whitesperformance on this stuff and I wouldn't hesitate to use them again. I ordered Thursday afternoon and the stuff arrived Sat. via Fedex.
The alt is a 100 amp 1 wire all new, not remanufactured and it's chrome, though I could care less, it just came that way for $65.00, the alt. bracket was $18.95.
The gaskets are the reusable type and they came with a set of valvecover studs/nuts.
The total kit was $14.50!
PostPosted: Sun Mar 23, 2008 6:21 pm
Good deal!!!
PostPosted: Sun Mar 23, 2008 7:09 pm
mytmouz, since you've got a lot more experience with this sort of thing...what do you think of the quality for the price? Just curious, seems to me like they know what they are selling, and I don't get the 'china knockoff' vibe from them...
Now you can easily see why I have a $400 watch list...LOL... :ewink
PostPosted: Sun Mar 23, 2008 8:11 pm
I have no complaints about the parts I recieved. Some of the stuff has got to be China stuff, but the inspection process must be a little stricter than usual. I'll definitely use them again.
PostPosted: Tue Mar 25, 2008 5:45 am
went to whites web site but no inventory/ parts page? mytmouz i like the alt set up but could not find anything on the site to look at or do you have to call them?
