It is currently Mon Feb 02, 2026 7:02 pm
 Post subject: help!
PostPosted: Tue May 29, 2007 12:00 am
Last week I got a 1976 Luv for free but I gave the guy 100 bucks since the ratchet shifter was 140, anyway.. It's a v6 3.8L out of a Buick 1979 with a 350 turbo (I don't know much else I'm just getting into cars). The only thing wrong with it was the carberator had a leak so my buddy and I swapped it with an extra one he gave us. We put in the other carberator and it started right up. It's got some decent power but my main question is how can I make this truck get as much power as possible? I have the whole summer to put all my time and a good amount of money into it. It's also pretty heavy weighing in at 5500 lbs. You guys and gals are the geniuses with these trucks so I figured I'd begin my education here! Also any tricks or tips on small things would be greatly appreciated I'm trying to learn as much as I can. Any tips or tricks would be awesome (Legal or not) i'm getting it smogged within the month and am trying to trick it out once I do so, but of course with the ability to transform it back before the next smog, thanks all!
PostPosted: Tue May 29, 2007 12:26 am
p.s sorry for posting in the wrong area :/
PostPosted: Tue May 29, 2007 2:19 pm
5500lbs 8O my half ton 4x4 didnt weigh that much
PostPosted: Tue May 29, 2007 4:27 pm
8O Yeah i would like to see where the extra 2000lbs is at. :?
PostPosted: Tue May 29, 2007 6:22 pm
yeah it doesn't even look heavy but that's what it says on the tag under the hood, i'll take some pics under the hood and of the truck then tell me what ya'll think
PostPosted: Tue May 29, 2007 8:41 pm
I'm not trying to be a wise guy, but if you look closer, I believe that's in kilograms. :lol:
PostPosted: Tue May 29, 2007 9:02 pm
Is it possible that is the GVWR
PostPosted: Tue May 29, 2007 10:15 pm
It would be less if it was in kilograms... I think there is about 2.1 or 2.2 pounds per kilogram... lol
I think its GVWR... I looked at the one on my truck, and it was something around that...
PostPosted: Tue May 29, 2007 10:21 pm
I'll check that out tomorrow :) im guessing you're right because i was amazed when i glanced at it and it said 5500 so maybe i didnt look close enough but ill check
PostPosted: Tue May 29, 2007 11:25 pm
Killer Sloth, 1 lb = 2.2 kilos, approximately, so 1000 lbs = 2200 kilos. So it actually would be more. :lol:
 Post subject: 5500 pounds
PostPosted: Thu May 31, 2007 12:02 am
Most of these trucks weigh in at anywhere from 2600 to 2900 pounds. If you have a 3.8 V6, those engines will run good. I would find out what factory specs are on the carb and start from there. It doesn't take much to mess up the way it runs when you just slap on another carb that is set up for a different engine. They aren't that hard to rebuild.
PostPosted: Thu May 31, 2007 2:17 pm
yeah it's 5500 MSVP or some 4 syllabel tag so it probably weighs 2500-3000. I want this thing to haul ass! I just put new spark plugs in it then im getting it smogged this week hopefully then make it smog-illegal and trick it out! suggestions on what to do? it's all stock v6 3.8L and that's it, i think a 350turbo whatever that is
PostPosted: Fri Jun 08, 2007 11:46 pm
ummm actually it's one kilo equals 2.2 pounds. Have to figure that everyday to give medical doses.
Let me xray you, you will feel better.
PostPosted: Sat Jun 09, 2007 10:05 am
OK :(
Users browsing this forum: Google [Bot] and 39 guests
