It is currently Mon Jun 08, 2026 8:15 pm
 Post subject: Tackling AC
PostPosted: Thu May 03, 2007 4:28 pm
Ac blows....kinda cool, but nowhere near cold... and t's fixin to get hot down here.
Here's a subject I know didly squat about, air conditioning. I understand the basic operation and components.
Situation: it apears a previous owner attempted or began a r134a conversion. While poking around I found the collector/dryer is an Atco 7-5144 originaly made for 83+ Chevy's, and the sticker on it says use r12 or r134a.
Looking at the compressor, a friend of mine tells me the fiting is not r134, so, I pressed in the valve stem pin and a little air came out, not like a whole lotta pressure but like a bicycle tire.
What I am wondering is, should I assume it is r134a and get a recharge kit & hope for the best? Is there way to tell which type is in there? Or do I need to have the system purged and vac'd first?
As for the recharge kits, anything in particular I should look for?
FIAA: Color Guard
PostPosted: Thu May 03, 2007 4:52 pm
I would doubt it is set up for R-134. I have a hunch that he could not find the correct receiver/dryer so bought a universal type. I would have it evac and Vac tested for leaks before recharging.
Something I hate to hear is "it just needs freon added". My answer as a mechanic that has done 100's of A/C repairs is "where did the freon that was in there go?". Freon does not wear out, and will not break down.
PostPosted: Thu May 03, 2007 5:38 pm
Thanks for the info, speaking of recharging, where is the valve on a Luv?
High and low pressure sides?
I found one on the backside of the compressor.
FIAA: Color Guard
PostPosted: Thu May 03, 2007 6:05 pm
http://s131.photobucket.com/albums/p289/johnboyp1963/
 Post subject: .
PostPosted: Thu May 03, 2007 6:20 pm
Thanks Johnboy. you da mang! :)
FIAA: Color Guard
 Post subject: .
PostPosted: Thu May 03, 2007 6:56 pm
Got 'er done. Blowing cold air, just in time today was about 87* 90% humidity.
Wanna thank yall for the info again, and a big thanks to Ben for getting this sight started. I keep thinking, if this site and info had been around 23 years ago, I'm sure I would still have that black 77 Luv :)
FIAA: Color Guard
 Post subject: .
PostPosted: Thu May 03, 2007 8:28 pm
So I finished the AC job, and like a responsible owner, I fill out the conversion info sticker and go to stick it under the hood. Well I noticed there was a rather faded one identical to the one I was sticking on. My guess is the previous owner did the conversion adapter, then for some reason removed it later.
It's all good now though.
FIAA: Color Guard
PostPosted: Fri May 04, 2007 7:01 am
:smt038
