It is currently Tue Jun 09, 2026 11:12 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 18, 2006 8:59 pm
You can use a early 80's(mine is a 82) master booster. They are aluminum instead of cast iron. The only thing you will have to get is the reseroir and run new brake lines from the cylinder to the differential pressure switch. I got a new one with reserior on ebay for about 45 dollars total cost.
PostPosted: Tue May 01, 2007 2:25 am
new master went in brakes work great but they are leaking fluid some where as it is all over the frame and on the ground but lines look good? not leaking from the booster like the old one? any idea what to look for
PostPosted: Tue May 01, 2007 5:25 am
If you overfill a master cylinder, it can push out the vent hole, (in the cap) when the brakes are applied. Might want to check that.
PostPosted: Tue May 01, 2007 10:08 am
Be sure the resivor clamps are tight, if not it will leak between the resivor and the master.
PostPosted: Tue May 01, 2007 6:43 pm
fixed fitting on master loose
PostPosted: Tue May 01, 2007 7:23 pm
So is it working now?
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Tue May 01, 2007 11:05 pm
Yes works great. Now I need to replace the cluth master as it is leaking on my foot and I have no clutch, and with out notice. that sucks
