It is currently Tue Jun 30, 2026 4:30 am
PostPosted: Mon Apr 30, 2007 2:39 am
well i ordered a cam from delta every thing was cool..... so i took the valve trian apart rocker arm assem. still attached put it the new cam started the engine the truck was rolling like a small block but the valves where still tapping so i called delta and i told them about the rocker arm ran out of ajustment they told me to reverse jam nut which i did so i had to take it apart again but this time i did not take apart the timing sprocket or fuel pump, now when i start it it runs like sh** . i checked valves to make sure the rocker arms where not to tight. all i did was change the jam nut was around . could of i bent valves if the rock arms where to tight. does any one known what could of happen? when i start this now i seem like the timing off or some thing and i checked compression it was 145 all around. has any one gone threw this before?
PostPosted: Mon Apr 30, 2007 3:06 am
Maybe you should have adjusted the valves to match the new camshaft?
 Post subject: thanks
PostPosted: Mon Apr 30, 2007 1:37 pm
i did int [.006] exh[.008]
PostPosted: Mon Apr 30, 2007 2:55 pm
What grind cam is it?
1975 V8 Luv
1980 Bagged Luv
 Post subject: cam spec
PostPosted: Mon Apr 30, 2007 3:20 pm
int dur 255.2 exh 253.2 stock # 790-292
 Post subject: i found what was wrong
PostPosted: Mon Apr 30, 2007 4:10 pm
the cam delta sent me the dur was to high for engine so thats y the truck would not run scott from delta told me to put my foot in it at 3000 rpm the truck started to run right dur to high. :oops:
PostPosted: Tue May 01, 2007 12:17 am
So is it a 260 grind 270 grind or a 280 grind? I was recommended the 270 grind for my application.
1975 V8 Luv
1980 Bagged Luv
 Post subject: yes
PostPosted: Sat May 05, 2007 6:26 pm
yes thats right well i'm still trying to get the lash out well right now its ex[.010] and int [.010] when i took all the lash out before it did not want to run but i'm waiting on a new to come by ups. [/b]
Users browsing this forum: Bing [Bot] and 27 guests
