It is currently Sun Apr 12, 2026 4:11 am
 Post subject: What are these from??
PostPosted: Thu Apr 19, 2007 8:59 pm
I think the Shifter Boot is from a 4x4 or mikado and the mirrors, I'm clueless But i think that they will look cool on the truck
Any one have a smaller diameter boot or larger diameter shifter?? lol trades welcome ya know. :?
PostPosted: Fri Apr 20, 2007 8:21 am
I think that the mirrors might be a dealer option... My parts truck has the same mirrors on it.
 Post subject: .
PostPosted: Fri Apr 20, 2007 8:39 am
Mirrors are 4x4
FIAA: Color Guard
PostPosted: Fri Apr 20, 2007 8:57 am
mmm.. maybe they came off the same truck....
PostPosted: Fri Apr 20, 2007 10:49 am
Yes, the mirrors are 4x4, and the boot is a 5spd boot.
PostPosted: Fri Apr 20, 2007 11:06 am
Banishment Pending
or a boot out of a 4x4...my old boot looks identical
PostPosted: Fri Apr 20, 2007 2:11 pm
Yep, all the 4x4s had that same boot. The shifter coming out of the trans is just a stub and has a larger diameter handle that slips on over it. 2WDs that part coming off the trans is solid all the way up to the handle.
You might be able to unbolt the shifter and swap the 4x shifter into a 2wd trans, though I'm not sure it is really doable without pulling the trans. Easier to change to the other boot, if you can find one that is in one piece.
An alternative would be coming up with something to fill the space, like turning a chunk of wood down so it just fits the shaft outside and the boot inside.
PostPosted: Fri Apr 20, 2007 2:23 pm
I think I will make like a little washer and put my leather boot from the 300zx ontop of that. Thnx for the infos. En1 have a close up of the mirrors installed so that I can Eyefeck in the at least correct position. Thnx in advance
PostPosted: Fri Apr 20, 2007 4:26 pm
Sirjic, meet 800xl, he is our resident LUV expert. What he says is 99.99999999% of the time correct. Piss him off and the help stops flowing. Just FYI
PostPosted: Fri Apr 20, 2007 4:31 pm
I don't think i said anything to piss anyone off did, 800xl?? I actually said i was prolly going to do what he suggested with the bigger diameter boot. 8O
PostPosted: Fri Apr 20, 2007 4:45 pm
No you didn't, but I have seen too many do it to him.
PostPosted: Fri Apr 20, 2007 6:27 pm
my 1979 2WD has the same mirrors and the same rubber shifter grommet...
PostPosted: Fri Apr 20, 2007 10:41 pm
Maybe they were put on afterwards, like I'm about to do haha. any pics of the locations fo the mirrrors??
PostPosted: Fri Apr 20, 2007 11:31 pm
Those are " below eyeline mirrors" and were a factory option on 77 thru 80 models according to my brochures. The doors are tapped for these mirrors from factory and on drivers door there are 2 stainless screws in holes to plug standard mirror mounting holes. They mount in line with original standard mirrors. There are pictures in galleries of these mounted on trucks....
PostPosted: Fri Apr 20, 2007 11:41 pm
Dan Has them They Look cool, Operation is GOOO! yut yut yut
http://www.luvtruck.com/Gallery/Dan/Picture%20002.html
http://www.luvtruck.com/Gallery/Johnnys ... uv038.html
Johnny too Mine hade the arms backwards short length goes to the bracket
oh wait a min, both pics have the arms different i think
Users browsing this forum: No registered users and 92 guests
