It is currently Wed Mar 25, 2026 6:23 am
PostPosted: Sat Apr 07, 2007 11:14 am
I know this topic comes up a lot but I have came across a 4 headlight setup that I would like to swap to my 79. I have a few questions:
1.) What are the inner two lights for? high beams/turn signals?
2.) Can I use the 4 headlight setup with my 79 bumper?
3.) Could I use 4 halogen bulbs? If so, would I have to upgrade any wiring, or would a higher amp alternator do the trick?
Thanks!
PostPosted: Sat Apr 07, 2007 1:05 pm
1. The inner two are high beams.
2. I don't think the bumper would matter.
3. If by halogen you mean the regular replacement bulbs that look the same as original but say halogen on the glass, then I would say no mods are necessary.
The grill will need to be narrower though.
PostPosted: Sat Apr 07, 2007 2:06 pm
I didnt think the bumper had anythin to do about it, but I was readin up on a previous thread and the bumper was mentioned. I miswrote the type of light, lol. The type of light I was meanin is the HID lights, I already have one set and was just wonderin if I had to do anythin else if I added another set. Thanks!
PostPosted: Sat Apr 07, 2007 2:09 pm
I have an extra set of headlight brackets from a dual headlight setup and was wonderin if I could use those for my inner light brackets?
PostPosted: Sat Apr 07, 2007 2:11 pm
:D I thought the halogen question was a no brainer, but I"d help you out any way. :D HID, I don't know. That's a whole different story , now. :D
PostPosted: Sat Apr 07, 2007 5:12 pm
The quad headlight is a direct bolt on. just remove all the single headlight parts and the grill and the dual headlight buckets screw right into the holes. The hid lights should work if you get the same size bulbs. Looks much better than the 2 headlight setup imo
PostPosted: Sat Apr 07, 2007 9:07 pm
The 2 bulbs are larger in dia. than the 4 bulbs, so you will need 4 more.
PostPosted: Sat Apr 07, 2007 10:12 pm
Really??? I didn't think they were, but I have never compared the two together either.
PostPosted: Sat Apr 07, 2007 10:42 pm
the older lights are like 5 1/2" and the newer ones are 7".
PostPosted: Sun Apr 08, 2007 12:23 am
Well my day was not wasted. I learned something new err.. old.... err.. new... whatever. at least I learned it. :lol:
PostPosted: Sun Apr 08, 2007 9:49 am
:D
PostPosted: Sun Apr 08, 2007 11:26 am
I already have a set of the new 7in crystal clear, so I would just have to buy another set which isnt a big deal. So I could use my extra brackets from a dual headlight setup for my inner brackets?
PostPosted: Sun Apr 08, 2007 11:53 am
The 2 light buckets won't work with the 4 light set up, the bulbs are larger. You will have to get the smaller 4 light buckets and bulbs.
PostPosted: Sun Apr 08, 2007 1:20 pm
I should probably read the post, lol. Thanks!
PostPosted: Sat Feb 16, 2008 7:45 am
so to drag up old post did you get the lights in your truck?
i was also thinking of doing this swap after seeing a 07 mustang in the rain last night.
