It is currently Sat Apr 04, 2026 7:46 am
PostPosted: Thu Feb 15, 2007 2:20 pm
Took the truck for an alignment today and they showed me some play in the upper control arm bushing and said I needed upper ball joints . How tough is this job ? Also has anybody rebushed the arm on the passenger side , as mine has slop in it and they don't offer a full replacment .
PostPosted: Thu Feb 15, 2007 9:31 pm
Upper BJ's are easy. These use 4 bolts instead of the usual press fit.
The idler bushings are available. I have a part # if you need it. I don't know how hard they are to install.
PostPosted: Thu Feb 15, 2007 10:01 pm
Thanks , Can I just jack it up and put stands under lower arm and dis assemble or do I need t opull out the torsion bar :cry: ? I looked at the manual I have and it looks like the upper contol arm bushings just thread in . I'm dreading the idler arm re-bush job worst of all .
 Post subject: idler bushings
PostPosted: Tue Mar 20, 2007 8:46 pm
by now you should have put them in.....if you haven't it is not hard.....just hope the cap on the idler arm is not cross threaded like mine was. Whoever did it last put in on that way......it was a really big vise and extension pipe on the rachet to get it off...............about the bushings. the last time i was in mine the rod thru the middle of the bushings needed to be replaced too........so plan on that too......
Let me xray you, you will feel better.
PostPosted: Wed Mar 21, 2007 7:05 pm
ben.. can you hook me up with that bushing number?
PostPosted: Wed Mar 21, 2007 8:06 pm
Sure, grab it off the box on my next trip down to the garage.
PostPosted: Wed Mar 21, 2007 8:15 pm
:lol: Sounds like you live in a mansion and have to ride the golf cart down the hill and out to where the garage is. :lol:
PostPosted: Wed Mar 21, 2007 9:00 pm
Still have not done this , but it don't feel horible at 115 mph .
PostPosted: Wed Mar 21, 2007 9:07 pm
Uh, the horrible feeling will happen when it comes loose. 8O
PostPosted: Thu Mar 22, 2007 12:07 am
LOL!
Not exactly, but the garage is separate from the apartment, so I try to make the trips count.
PostPosted: Thu Mar 22, 2007 12:45 pm
The one I have is a Beck Arnley part number. They appear to be the correct ones, although I haven't installed them yet.
The box has: 101-3863, then 49-14605 on one end. The skew on the side is 0 49797 15965 2.
PostPosted: Thu Mar 22, 2007 1:32 pm
tpoter i think it's more like the oh $*IT feeling when that happens. 8O and then :onfire:
PostPosted: Thu Mar 22, 2007 1:45 pm
That was kinda sorta a joke . Mine are not to the point of failing , just have small amounts of play in them .
PostPosted: Thu Mar 22, 2007 9:33 pm
:lol:
PostPosted: Fri Mar 23, 2007 4:29 am
I have a race on saturday , then thing sorta shut down for the nationals . I will be working on this front end stuff then . Any helpful hints would be greatly appriciated .
PostPosted: Sun Mar 25, 2007 9:59 pm
I just had my truck 'diagnosed' and was told it needs a tie rod, all ball joints and a pitman arm. I've already ordered the ball joints, but I'm not having any luck with the tie rods. Are they still available? Anyone have part numbers for a pitman arm?
Besides lots of cussing, anything special I need to do to unload the suspension to replace the ball joints?
PostPosted: Sun Mar 25, 2007 11:06 pm
i ordered my tie rods from rare parts via autozone... i don't know about the pitman arm
PostPosted: Mon Mar 26, 2007 4:47 pm
:?: A refresher please?
Last car I worked on with torsion bars up front was a '69 Charger with a factory slant 6...
Could one of you show me a link or a give me a quick run down of what I need to do to change the tie rods and ball joints in the LUV?
I have a manual coming, but usually experience will take hours off of a job described in the manual.
Thanks!
Users browsing this forum: No registered users and 103 guests
