It is currently Mon May 25, 2026 3:43 am
 Post subject: 1.9 or 2.3
PostPosted: Mon Mar 15, 2004 7:47 pm
Ok looking at adding a 1.9 or 2.3 isuzu engine. If any one has done this with pics could you post them? also and mods like cams, turbo or anything for these engines? Does any one know if the 2.3 needs fabd motor mounts? thanks for your relpies. also i am selling my 1.8 and tranny!!
PostPosted: Mon Mar 15, 2004 8:57 pm
i just pulled out a 1.9 today to put in my luv, i'll get some pics, i think the 1.9 is a little stronger motor than the 2.3 because the 2.3 has a timing belt, and i've never like a timing belt, i prefer timing chains. the 2.3 would be more powerful so i guess it would be the choice to put in if you were gonna go buy one of them. i had the 1.9 so i decide to swap it. don't sell your tranny, the 1.9 and 2.3 will bolt up to your stock tranny.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Mon Mar 15, 2004 9:53 pm
Did the 1.9 bolt right up? mounts and all/ I want to get the 5 speed isuzu tranny. do you know if the isuzu tranny has hydrolic clutch. if you have any pics of the 1.9 installed let me know. do you still have the stock carb on? thanks for the info.
PostPosted: Mon Mar 15, 2004 10:52 pm
i pulled the 1.9 out today, i still have to pull out the 1.8 and install the 1.9 in the luv. everything looks the same. i'm going to be using a stock 1.9 carb out of an earlier isuzu truck. the one on the truck now is computer controlled. i have a hitachi carb off a 1.9 that was on my 80 luv for awhile till i got the carb off my 80 parts truck. all the motor mounts and bellhousing pattern look the same. i'm pretty sure the 5 speed isuzu tranny has an mechanical clutch, not hydraulic. i will take my digital camera out with me to work tommarow and take some pics of the swap process.
 Post subject: 5speed trooper tranny
PostPosted: Tue Mar 16, 2004 2:35 am
The one I pulled didnt have a hdyralic clutch. The crossmember I had to cut out, made the need for a brakcet that boltsto the tranny for the E-brake cable. If you do go with the 5speed, you will need the removable crossmember and the 4wd driveshaft (to the front axl). Also your stock driveline will need to be shortened with a new yoke on the end.
My mechanice welded brakets for the removable crossmember.
heres a linke of the post on mine:
http://forums.luvtruck.com/viewtopic.php?t=2207
PostPosted: Tue Mar 16, 2004 4:18 am
i know the Isuzu MUA5 tranny is a hydro clutch. I also know that it had a diferent bell housing pattern than a 1.8L whith a 4 speed. So be carefull about the donor vehicle if your trying to keep the LUV 4speed. A 2.3L or 2.6L from a trooper will be diferent.
