It is currently Wed Jun 10, 2026 12:25 am
 Post subject: O2 sensor
PostPosted: Thu Jul 04, 2019 9:27 am
Has anyone rigged up an O2 sensor on their carbureted LUV with a meter for determining the air/fuel mixture? I know that they are sold as kits at parts stores. If so, did this modification help you to get through the emissions tests any easier.?
 Post subject: Re: O2 sensor
PostPosted: Fri Jul 05, 2019 8:29 pm
I think my son has. I text him to check this post.
PostPosted: Fri Jul 05, 2019 9:02 pm
Yeah I have one on my truck. Welded the bone for the sensor just below the manifold joint.
Well I didn't have any issues with smog before I put it in so no it didn't help me. And the smog tech didn't pay any attention to it.
PostPosted: Sat Jul 06, 2019 3:15 pm
Did it help in adjusting your carb to best burn?.....Or was the carb too worn out to be correctly calibrated to achieve best burn? I have a fairly new factory carb and I can't get it to burn 'clean'. Did the 02 sensor and gage work out?
PostPosted: Sat Jul 06, 2019 3:16 pm
Also....Nice Dash!! where did you get it?
PostPosted: Sun Jul 14, 2019 7:58 pm
Yeah, I suppose. I was able to Target real close to stoich at idle. And verify that it wasn't too rich or lean @WOT.
It also helps me realize that I was having vacuum leaks and other issues, because I noticed the AFR would randomly change from what I normally was. (Carb was actually vibrating loose despite being lock-tited)
No my carburetor was actually almost new, a Weber 32/36.
It's a factory dash.
I threw in that little tack not long after I bought the truck just to know what kind of RPMs I'm running down the highway or down the trail.
I just had some gauges left over from previous vehicles (act, egt, and vacuum/boost) and then when I had the engine rebuilt I added actual water temp, oil temp, and oil pressure gauges.
PostPosted: Wed Jul 17, 2019 7:55 pm
A few pics in the day time.
