It is currently Mon Jun 08, 2026 10:53 am
 Post subject: vacuum line
PostPosted: Sat May 27, 2006 10:21 pm
does the egr have a vacum line running from it my vacum diagram says it does but i looked all around it and cant see it
of course it hurts you are being screwed by an elephant
 Post subject: egr vacuum line
PostPosted: Sat May 27, 2006 10:49 pm
yes.
the following are instructions for my 78' luv...
your egr valve should have a vacuum line running from itself to what i think is called a ('vacuum advance'?) - this is attached to the intake manifold closet to the distributor, aka water gallery. then another vacuum line runs from the ('vacuum advance'?) to the carbeurator for vacuum.
that should at least help.
"Experience is a hard teacher, for she gives the test first, and the lesson afterwards."
1978 Chevy LUV - 2WD - [Work In Progress]
w/1976 1.8L 1815cc Stock Isuzu Motor
http://forums.luvtruck.com/viewtopic.php?t=8843
PostPosted: Sun May 28, 2006 6:39 am
The vacuum line comes from the egr valve to the thermal vacuum valve on the intake(front side of engine) then goes to the time control vacuum port on the passenger side of the carburetor. At least for a 1978 truck.
Users browsing this forum: Google [Bot] and 53 guests
