It is currently Mon May 25, 2026 10:33 pm
PostPosted: Wed Aug 09, 2006 4:17 pm
Just bought a '77 Luv and am in the beginning process of doing a SBC swap.
From the LUVTruck.com's 'Beer Budget' technical article they suggest the Howe Unversal Aluminum Radiator (#HOW.342B). I also found 2 other radiators the same size that appear to fit the size requirements are cost slightly lower.
-SIMMIT- Griffon GRI-1-25182-X 189.99
-JEGS- #555-51185 & #555-51171 $169.99
Has anyone used them or know if they're worth the few bucks in savings?
Thanks in advance.
-Scott
PostPosted: Wed Aug 09, 2006 4:55 pm
Speedwaymotors.com sells one for 149.95 19" X 22"
http://www.speedwaymotors.com/xq/aspx/p ... roduct.htm
The only real setback is that these will require a trans cooler if you run with an automatic.
PostPosted: Wed Aug 09, 2006 5:43 pm
Great find- thanks!
PostPosted: Wed Aug 09, 2006 6:28 pm
I used the same size Griffin radiator and the trans cooler is no problem just fab a bracket and put it behind the licence plate I even used the same bolts just make sure there is as much clerence as possible all the way around the cooler.
PostPosted: Wed Aug 09, 2006 6:35 pm
Thanks in advance.
-Scott
PostPosted: Wed Aug 23, 2006 2:43 pm
I'm having trouble finding a lower radiator hose. Any suggestions?
PostPosted: Wed Aug 23, 2006 3:02 pm
Measure the length and size of the hose you need and go to the parts store. They got to have a flex hose hanging on the rack that will work.
PostPosted: Wed Aug 23, 2006 7:04 pm
I have a flex hose on mine it will work but it is TIGHT. Make sure you clear fuel pump and fuel line. I put a little extra padding on mine for just in case.
 Post subject: radiator
PostPosted: Wed Oct 25, 2006 3:35 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
i got the griffin on mine and even on the hottest days at the track it never gets over 140
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
PostPosted: Wed Oct 25, 2006 7:37 pm
I have the summit radiator in my truck.Hey hotrod I went with the Mr gasket stainless steel radaitor hose kit from jegs p/n 720-11014.On the upper and lower.Bends and cuts easy.
PostPosted: Wed Oct 25, 2006 9:34 pm
Cool I'll check into that.
