It is currently Wed Mar 18, 2026 11:43 am
 Post subject: Abrasive Blast Cabinet
PostPosted: Wed Feb 21, 2007 12:45 pm
I am thinking of buying a blast cabinets and wondering if any one has some experience or learnings they can share. like
guns and nozzle
compessor needed
type of abrasive media to use..
or???
Current Fleet
pics
PostPosted: Wed Feb 21, 2007 2:36 pm
http://cgi.ebay.com/ebaymotors/SAND-MED ... enameZWDVW
here is one on ebay
PostPosted: Tue Mar 06, 2007 6:20 am
I have a larger floor model . They make alot of dust if you don't have a collection set up . It takes a pretty big compressor to run .
PostPosted: Tue Mar 06, 2007 9:20 am
I ended up buying the $199 floor model at harbor freight. I bought the walnut shells for the abrasive but they would not go through the gun. So i bought some glass bead. seems to work ok. dust was not bad but I know it will get worse as the blast media breaks down. For the dust collector i was thinking of running the vent hose into a bucket of water for a poor mans dust collector. Don't know how much I will use it but it seems handy to have around. I am running it on a 60gal compressor not having any problems even though the recommended the you needed 16cfm to run it. i don't believe many of the specs from harbor freight
Current Fleet
pics
PostPosted: Wed Mar 07, 2007 5:55 am
That's the one I have .I also have glass bead in mine . I stuck a vacuum cleaner bag on the outlet to cut down on dust .
PostPosted: Wed Mar 07, 2007 10:45 pm
I have the big one Harbor Frieght sells. Everything good except the cheap gun. I replaced phony rubber valve seal with a ball bearing and modified the seat to fit bearing, and it works good. You need to hook outlet up to vacuum or a ventilator or you can't see sh*t through window. I use a big 80 gallon 20+ cfm compressor, so no problems there. I use Green Diamond silica free media. I like it better than glass beads for what I blast.
