It is currently Tue Nov 04, 2025 6:41 pm
PostPosted: Tue Aug 20, 2002 8:49 pm
:D
Hey - I am doing the 350/350 conversion and am wondering?
I have a '76 luv and want to use the stock harness.....which gm alternator is the easiest to install?
Thanks for your time,
Giles5
Get in-Sit down-Shut up_hold on!
PostPosted: Wed Aug 21, 2002 12:14 am
i used the stock alt with a chrome bracket off the header bolts on the
left side of the motor i think there is a pic in the main gallary
PostPosted: Wed Aug 21, 2002 5:34 pm
I am using the stock alternator also. Try autofab, which is where I got my install kit from. It came with the bracket to mount the stock alt onto the motor (mine is a v-6) but they should have v8 ones also. The only thing I had to do was lengthen the wires as it mounts on the other side of the motor now.
 Post subject: GM Alternator
PostPosted: Wed Aug 21, 2002 9:56 pm
I myself wired in the GM alternator and it has worked flawlessly all these years. The amperage increase is a major plus, and the stock voltage regulator is no longer needed. If anyone needs a basic wiring diagram, sent me an e-mail and i'll send you one.
