It is currently Tue May 26, 2026 12:59 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 328 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 17  Next
PostPosted: Sat Feb 03, 2007 10:16 pm
It is Saturday and still no word from the guys at the machine shop. I have no clue what the deal is unless it is weather related due to icy mountain roads.
Quote:
OK the ultimate ? Why is it so important to have 5 lugs on the front anyway other than rim matches.
My reason for converting the front to 5 lug is with a S10 spindle I can go with a larger rotor/vented and slotted, larger calipers w/ mulitipul pistons, drop spindles, easier to find parts to replace/repair, and of course larger verity of rims.
PostPosted: Sun Feb 04, 2007 10:04 pm
I'm dying over here. give them a call tomorrow morning at 6:01 am.
1977 Chevy Luv
350/TH350
PostPosted: Tue Feb 13, 2007 7:26 pm
Almost 10 days past. Got them plates?
1977 Chevy Luv
350/TH350
PostPosted: Thu Feb 15, 2007 3:24 pm
I just got them the day before yesterday. I have been working in overdrive since last week trying to make up the time I lost due to pretty much being blind due to a couple of nice chunks on metal in my eyes. Been pretty much putting in 12-18 hour days this week trying to catch up on everything. I have been neglecting everything trying to get everything straightening back out. I have to send you your plates, hotrod80 his e-brake handle, and Rick Smith his e-brake cable. I will try to get them all out soon. I am currently doing some paper work for the shop so I was able to finally sneak in a little LUV time.
PostPosted: Thu Feb 15, 2007 4:55 pm
Shit in the eye, Ouch. Glad to hear you are ok.
If you get around to having a couple of more made, put me down for a set.
My redrilled rotors that I had found got sold before I could get them.
Richard
PostPosted: Sun Feb 25, 2007 10:56 pm
Send them plates please
1977 Chevy Luv
350/TH350
PostPosted: Fri Mar 02, 2007 11:09 pm
Plates? Do they exist?
1977 Chevy Luv
350/TH350
PostPosted: Sat Mar 03, 2007 7:04 am
Hope they do. Want some too
PostPosted: Sat Mar 03, 2007 10:35 am
Well Blackluv80 since everybody is giving you hell :oops: for some plates i might as well and whine to and say i want a set the i can see if my rack-pinion will work with the S-10 spindles.When ever you get a set.Thanks
PostPosted: Sat Mar 03, 2007 4:43 pm
I have taken it upon my self to get some made here in AZ. I am making an extra set that I will sell to anyone who wants them. I will not be drilling the 2" ball joint hole I dont think but the shape will be what you need and the 4 mounting bolt holes will be there.
$100 for 2 plates.
1977 Chevy Luv
350/TH350
PostPosted: Sat Mar 03, 2007 10:01 pm
I had an extra set of bushings made for the toyota rotor conversion .
PostPosted: Sun Mar 04, 2007 7:09 pm
Hotrod 80 how is that conversion doing any how?
PostPosted: Sun Mar 04, 2007 7:19 pm
I have completed the conversion , but torn up the trans . Worked pretty good though .
PostPosted: Mon Mar 05, 2007 8:24 am
This what i like to hear is a driver who is smart enough to know that there is a problem with his ride ,checks it out, then fixes the problem before it gets worse or loose a race and still slap his fore head because he knew better. My hats of to you HotRod80 for sticking with the conversion and locating and fixing a problem when it needed fixing.
PostPosted: Mon Mar 05, 2007 11:26 am
The clearencing was the hardest part for me . I don't have a air compressor so everything has to be done by hand . I only have 1- 110 volt outlet in the whole garage :( , but I enjoy working on these projects .
PostPosted: Mon Mar 05, 2007 5:32 pm
Did you by any chance take any pic's. of your clearance issues?
PostPosted: Wed Mar 07, 2007 3:49 pm
Okay as you all know I have been extremely busy as of late. So it is hard for me to find enough time to run to town but I think I have finally caught up with everything. Rick Smith's E-brake cable and Hotrod80's E-brake handle was sent out yesterday. Hyperwrx your plates was sent out today I will send you the track number here in a few. I actually got the 1st set of plates back from the mail that where lost, so I thought. So I have one additional set of hand made plates so I believe I will play with them and attempt adding a lock ringed lower ball joint. mytmouz I know I am extremely late with you aswell I will send you your $ as soon as I can. Again to all I am sorry but I am only human. Fulla or John if you still need the wiring for you gauges let me know I will send it along with the $ I promised to send you to help ya out.
However...Truck update.
I have all the steel, rods, and rod ends to convert the rear suspension to parallel four link and relocate the shock mounts behind the rear end. I will start cutting this weekend hopefully.
I have tons of updated pics and I will post them as soon as I have the time.
but for now I have to get back to the shop and work on a 06 mustang some young retard hasn't even put 20,000 on it and torn out the clutch, scared the flywheel with the rivets, and cracked the flywheel.
PostPosted: Wed Mar 07, 2007 6:59 pm
I had the local high school try to make me a set with a computer controlled plasma cutter and they failed miserably. Cutter wasnt rated to go 1/2" deep
I need your plates. Send me the trackig please so I know they are o the way.
1977 Chevy Luv
350/TH350
PostPosted: Thu Mar 08, 2007 2:21 pm
Come on man, give me that tracking number.
1977 Chevy Luv
350/TH350
PostPosted: Sat Mar 10, 2007 10:34 pm
Was it even sent?
1977 Chevy Luv
350/TH350
