It is currently Tue May 26, 2026 12:10 am
 Post subject: replacement door???
PostPosted: Thu Mar 01, 2007 6:38 pm
Are all the doors in all years of the luvs interchangable, also, will any other chevy (s-10) or izusu door fit on my 79'. Thanks i appreciate it :D
PostPosted: Thu Mar 01, 2007 7:55 pm
All Luvs between 72 and 80 I believe will interchange although the door glass is different over the years. The difference being some have a vent (winged) glass and others have a larger one piece glass.
Although a luv is the only thing I know of here in the states that will bolt up to a 72-80 Luv.
81-82 Luvs and Isuzu Pups I believe have the same doors, but wont work with a 72-80 Luv.
PostPosted: Fri Mar 02, 2007 12:37 am
Blackluv is correct about interchanging doors. They are the same, minus a shim or two to line it up. But the difference is up to 76 they had the wing windows and from 76 to 80 they had the one big glass. I have not heard of any other doors that would swap out, plus the body line would not match up to the truck, that might look a little funny.
-Austin
PostPosted: Fri Mar 02, 2007 1:30 am
My '78 has the original doors, with wing windows...
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Fri Mar 02, 2007 10:07 am
Thats impossible, unless the factory had a couple of doors laying around for 3 years. :roll: How long have you owned the truck??? I see it isnt the original paint.
PostPosted: Fri Mar 02, 2007 10:01 pm
i thought 77 was the last year for vents
PostPosted: Fri Mar 02, 2007 10:19 pm
Yep, you are right (as always!!!) :D .
