It is currently Sat Mar 21, 2026 8:46 am
PostPosted: Tue Apr 22, 2003 10:22 am
I can't seem to find a fuel filter anywhere on my 77' Luv 1.8 2wd. I have had the carb rebuilt and smog stuff removed but the truck will still spit and sputter while excellerating(does it sparatically). I was thinking the fuel filter may be clogged but I can't find it...or maybe the fule pump is going bad. Anyway...can anyone clue me in on this??? Thanks!!!!!!
PostPosted: Tue Apr 22, 2003 11:05 am
There's 2 filters on the truck. One is up in the engine compartment and the other is back between the tank and fuel pump. Look up under the bed of the truck just forward of the gas tank filler tube. It mounts on the frame. you might as well change the fuel lines too from the tank to the filter and from the filter to the pump. Odds are they are original and will need replacing.
PostPosted: Tue Apr 22, 2003 1:03 pm
THANK YOU!!! I WILL REPLACE THEM AND SEE WHAT HAPPENS.
PostPosted: Tue Apr 22, 2003 1:05 pm
BY THE WAY...I FOUND THE ONE BY THE FUEL FILLER ATTACHED TO THE FRAME BUT CAN'T LOCATE THE ONE IN THE ENGINE BAY.
PostPosted: Tue Apr 22, 2003 1:33 pm
You should find the fuel line from the carb and follow it back. If it's a stock carb, you have 2 lines at the carb. Follow the bigger fuel line. If you follow it back all the way to the metal line goes underneath the truck, it must have been removed previously. My 75 Luv had the filter on the drivers side fenderwell. I cant remember where the newer Luvs have their filter located. If it turns out that the filter is gone, it would be a good idea to install one.
PostPosted: Tue Apr 22, 2003 1:34 pm
Yeah...mine must have been removed at some point. Thanks for the info and advice!!!!
 Post subject: fuel filter
PostPosted: Thu Apr 24, 2003 8:53 pm
There is also a fuel filter inside the electric fuel pump. The end of the origional electric fuel pump will come off to reveal the fuel filter.
Users browsing this forum: Bing [Bot] and 51 guests
