It is currently Wed Jul 01, 2026 12:03 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Feb 25, 2007 11:44 pm
Swap Specialist Mod
FullaLuv wrote:
Whew! Okay then. What if I rev it to the tops of the trees?
itll be fine. a stock cam will only make power till about 5200rpms. ask me how i know! lol
5000prms on an unbalanced 4 banger is not problem as long as its got good oil pressure. heck, ive had the pup up to 6500rpms, but was just making noise. no power up there.
but with the cam that i might buy from a guy in australia, ill have power till about 7500. 297duration at .470lift with a 110LSA 8O itll sound gooood!!
PostPosted: Mon Feb 26, 2007 12:05 am
i think thats the one in mine it had 470 on it... the valves have always made noise but you can hear the lump in the cam
PostPosted: Mon Feb 26, 2007 12:24 pm
Banishment Pending
:twisted: :twisted: :twisted: Me likey the sound of your engine
PostPosted: Mon Feb 26, 2007 11:18 pm
hay thanks
PostPosted: Mon Feb 26, 2007 11:34 pm
Swap Specialist Mod
well i picked up a g180 engine today with a good head on it. the cam journals are super clean, so this is the one im gonna rebuild.
does anyone know if a g200 rocker assembly will work on a g180 head? id rather use the g200 rockers on this engine, since they look stronger.
PostPosted: Tue Feb 27, 2007 12:29 am
Swap Specialist Mod
well i have the cam lined up now.
im buying a cam, AND an adjustable cam gear from a guy on http://www.ozgemini.com
the cam will spec out at 297*int/exh, and .470in lift with a 110LSA.
its gonna cost me about $130US, but for what im getting, i think it worth it!
now, i need to start worrying about how im gonna feed this monster! i dont think a motorcraft 32/36 weber wannabe is gonna cut it for the cam. guess i need to start lookin for a 4 barrel intake or somethin like that. either that, or find a 38/38 weber, and i dont think thats gonne be happenin. 8O
heres a pic of the cam gear too...
i get paid on the 2nd, and the 5th, and get my tax returns soon, so this is going to happen! im jacked!
PostPosted: Tue Feb 27, 2007 12:34 am
i am running the 32/36 right now because i didnt get the twins tuned before winter, will try again this summer... but the truck runs good with the 32/36 not as well as it could but for now untill you find something different it will work..... how much for the cam gear only
PostPosted: Tue Feb 27, 2007 12:38 am
Swap Specialist Mod
im not sure on just the gear. hes selling the cam and the gear as a set.
id like to run twins like your setup, but thats a whole hell of alot of dough i aint ever gonna have. that and i could never get em tuned.
id like to stick with one carb anyways. then i wont have to worry about gettin them sync'd up and stuff like that. im thnkin i need to start looking on ebay for a 38/38 or something of the sort.
PostPosted: Tue Feb 27, 2007 12:51 pm
Banishment Pending
38/38 would be my choice, although a 32/36 will work
PostPosted: Tue Feb 27, 2007 7:38 pm
Swap Specialist Mod
well right now, i can tell the 32/32 ran out of air at about 5500. it would fall flat on its face there.
with the cam im getting, im gonna need about 320CFM to support it, so i might look into a holley 2 barrel. the ones that look like half a 4 barrel. i was looking at maybe one large SU carb too.
PostPosted: Wed Feb 28, 2007 1:16 am
Swap Specialist Mod
well i have bid on a holley 350CFM 2 barrel. the auction ends in like 18 hours, so i hope i win it. the auction is up to $51, so that wont be bad.
oh, i also moved this thread to 'drivetrain upgrades' since this inst a very stock engine, or truck anymore. :lol:
PostPosted: Wed Feb 28, 2007 1:30 am
there is a guy here in town... and old speed shop , he is like 80/90 years old and been doing it sence the 30's he has some NOS 4 barrel intakes for the luv if you need one
PostPosted: Wed Feb 28, 2007 1:32 am
Swap Specialist Mod
4 barrel intake eh? how much? this sounds interesting!!
you have any pics of a 4 barrel intake for a G series? i could find a way to adapt the 2bbl to it prolly.
PostPosted: Wed Feb 28, 2007 10:04 am
ill try to get buy there and see if i can get a price and pics might take a day or two
PostPosted: Wed Feb 28, 2007 7:00 pm
Swap Specialist Mod
mkay! take your time. im in no hurry! lol :D
PostPosted: Wed Feb 28, 2007 7:24 pm
Swap Specialist Mod
well i didnt win the auction for the carb. kinda sucks.
anyways, im gonna talk to my dad and see what hes got for carbs over at his place. i remeber him havin a matching set of stromberg SUs that would proll work pretty well on my engine. ill have to build an adpater to run em, but it shouldnt be that hard.
PostPosted: Tue Mar 06, 2007 2:11 am
Swap Specialist Mod
well after some thought, and working with some ratio calculators, ive come to the conclusion that im gonna run 4.56 gears.
i was thinkin about it, and with the 410s, and the luv tranny with the lower 1st gear, i would have no 'get off the line' unless i revved the piss out of it and side stepped the clutch.
also, at the end of the track, i would only be at like 3800 rpms with a 24 inch tire. and with the cam im getting, my power band is going to be like 3000-7000rpms. so with the 4.56s and a 23.5in tire ill be around 4900rpms at the traps.
that and the truck will be a hell of a little get around town truck. lol. i dont think anyone will expect this thing.
PostPosted: Tue Mar 06, 2007 12:38 pm
Banishment Pending
so this mean your going with the 12 bolt? :twisted: :twisted:
PostPosted: Tue Mar 06, 2007 12:58 pm
Swap Specialist Mod
im not sure yet. theres a guy here local that has a stock luv rearend with 456s that im thinkin about pickin up from him. since im stayin with the 4 speed, another stock rearend will just bolt in.
im not totally shutting down the 12 bolt idea though
PostPosted: Tue Mar 06, 2007 5:04 pm
Banishment Pending
Come on you know you want factory rear disc's, beefy axles and an available lsd and other goodies :twisted:
I'm just saying...
