It is currently Tue Feb 03, 2026 6:55 am
 Post subject: locker
PostPosted: Wed Feb 14, 2007 2:56 pm
does anybody know if i can get a locker for my 2 wheel drive? I got stuck twice about a week ago and I had to get my dad to pull me out with a :oops:Ford:oops: tractor when my friends Jeep wouldnt budge it.
PostPosted: Wed Feb 14, 2007 4:04 pm
i think they are the same as the ones u can get for the troopers and stuff
PostPosted: Wed Feb 14, 2007 8:22 pm
I don't think there is one you can buy for the stock LUV rear axle. You could always " Lincoln Lock* " it if you wheel allot.
*Lincoln Lock: Welding the spider gears to each other, making them work like a spool.
Looking for that special LUV.
PostPosted: Wed Feb 14, 2007 9:10 pm
Also known as Miller tracking cheap,works can be a through away though i have seen them last though :wink:
PostPosted: Wed Feb 14, 2007 9:25 pm
Banishment Pending
Independent 4x is now selling a Aussie Locker for the Isuzu 10 bolt axle (the rear axle you have in your truck) that would be aabout as close to a locker as your going to get. ARB makes a selectable one but it runs about $700+ and then you need a air source. The Aussie locker is around $300, check this site out for more info
Indy4x
PostPosted: Wed Feb 14, 2007 10:47 pm
Hmmm well i was just reading it and it says early isuzu pickups
that means it would be okay for a 79 luv right?
PostPosted: Thu Feb 15, 2007 3:07 am
I can get an ARB Air Locker for my truck???!!!!!
Cool Beans!
PostPosted: Thu Feb 15, 2007 11:14 am
Banishment Pending
Yup, they all have the same Isuzu 10 bolt rear axle.
PostPosted: Thu Feb 15, 2007 5:54 pm
More to the point, the front Isuzu 10 bolt is the same basic diff as the rear 10 bolt in our LUVs.
PostPosted: Thu Feb 15, 2007 6:23 pm
Banishment Pending
What he said :lol:
PostPosted: Thu Feb 15, 2007 7:29 pm
anyone wana buy me two lockers?
PostPosted: Thu Feb 15, 2007 10:11 pm
wow guys thanks, i will probably get one soon so we can leave the FORD at home where it needs to be
PostPosted: Fri Feb 16, 2007 12:33 am
Banishment Pending
No locker available for the Luv front axle, it's an Isuzu 8 bolt, not a 10 bolt
PostPosted: Fri Feb 16, 2007 9:00 am
o sorry i must of misread it
 Post subject: Indy4x
PostPosted: Sat Feb 17, 2007 12:54 am
While you're at the Indy4x site, you'll notice a picture of an Trooper, with and Chevy Bowtie emblem on the grill? What year would that be, and what the???????
1980 Chevy Luv 4x4 Mikado
the "Ole Man from Spokane"
PostPosted: Sat Feb 17, 2007 1:34 am
Banishment Pending
That would be Matt's rig, he's the owner of Indy4x, it's a 1989 Isuzu Trooper RS, D60 front, 14bt rear(I think, it may be a D70) 350SBC,D300, SM465 yada.yada.yada. He put the Bowtie on after he built it, since it does have a Chevy drive train under it kinda fitting.
PostPosted: Sat Feb 17, 2007 9:55 pm
i would definately go with the lincoln locker. they are very stout... if i get another 2wd i am doin it for off-road. sand, mud, snow, etc... they definately help tho, my 4x has the spiders welded together...
muddy luvs are like sex. ya just cant get enough of either.
PostPosted: Sat Feb 17, 2007 9:59 pm
So yea when u weld the front how dose it drive in 4wd?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Feb 17, 2007 10:33 pm
When you weld the front, you can't turn with it locked in. You can unlock one hub to turn, but have to get in and out to lock and unlock it.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Mon Feb 19, 2007 9:44 pm
So when your in 4wd u cant turn the tires
79 4x4 1.8 liter
