It is currently Tue May 26, 2026 10:16 am
 Post subject: driveshaft bearing help
PostPosted: Thu Feb 15, 2007 9:44 pm
just wanted to say this is a great site, lots of information. quick question...
81 luv 4x4 w/ 2-piece rear driveshaft, shucked the bearing tonight. how hard is it to replace? take off the 4 bolts at the rear axle housing... the front is a slip yolk??? does the bearing just slide off the shaft??? thanks
PostPosted: Fri Feb 16, 2007 6:31 am
i dont know but im doing mine today on my 81 i let you know it goes when im done
92 gmc on 35/12.50/15
81 luv on 31/10.50/15
PostPosted: Sun Feb 18, 2007 12:08 pm
ok the bearing on the shaft is fine, but theres a bug rubber piece around the bearing wth a metal sleeve that has two tabs that hold onto this housing, that rubber piece is torn to shreds and the driveshaft is flopping in the housing, no parts stores can get that rubber piece, can anyone help here?????
