It is currently Mon Jun 08, 2026 6:57 pm
 Post subject: No fire to points ???
PostPosted: Tue Feb 13, 2007 11:02 am
I have a 1979 luv with 1.8 in it. I started having trouble with moisture in the dist. Got rid of the moisture now it will not crank. Tried new wires, plugs an points. still will not crank, found out I was not getting any fire to points. Does anyone have any ideas?
Thanks
 Post subject: just a guess
PostPosted: Tue Feb 13, 2007 11:24 am
My guess would be coil or ballast resistor.
FIAA: Color Guard
PostPosted: Tue Feb 13, 2007 8:20 pm
Check for voltage on both side of the ballast resister if voltage present then check coil.
 Post subject: no fire to points
PostPosted: Wed Feb 14, 2007 8:24 pm
Thanks it was the ballast resister. Now I have voltage all the time to points even with the switch off. What do you think?
I was thinking the voltage reg. might be stuck!!!
Thanks
