It is currently Tue May 26, 2026 12:11 am
 Post subject: rear leaf spring ?
PostPosted: Wed Feb 14, 2007 7:24 pm
Anybody bent the factory leaves on the rear ? I think I have bent mine at the shackle in the rear . Also the clamps on rear side of the leaf are wearing into the main spring . I'll try and post a picture of them .
PostPosted: Wed Feb 14, 2007 8:55 pm
Seen them bent on the front using slapper bars but never on the rear.
PostPosted: Wed Feb 14, 2007 10:40 pm
I have had the rear shackles flip, it may be starting to do this.
PostPosted: Wed Feb 14, 2007 10:52 pm
sounds like no bueno
PostPosted: Thu Feb 15, 2007 4:48 pm
Plenty of spring shops in Houston. They can straighten them, rebush them and retemper them. They can add a leaf or two. Or even build you a heaver duty set of springs. with out making it ride rougher too.
I have worked with Cole Spring and Herbert Hiteman Company. Both do good work.
Richard.
PostPosted: Thu Feb 15, 2007 11:12 pm
Japanese Redneck
sounds like a lot of weight was placed in the bed maybe? i dunno... the front gets bent really easy if you use slapper bars and really really easy if you use cal tracs.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Fri Feb 16, 2007 9:48 am
I have slapper , but the snubbers are under the spring eye .
PostPosted: Sat Feb 17, 2007 9:46 am
It's this situation that i like my ladder bars.I still use my springs(over load removed)but nothing to bend,and it hooks hard to.
PostPosted: Mon Apr 23, 2007 9:14 am
Well , I can tell you DON'T pull the slapper bars to help wieght transfer . I did this last night and crushed the factory leaves . It pulled the wheels so hard it drug the trailer hitch on the ground . Now i'm changing springs .
PostPosted: Mon Apr 23, 2007 9:22 am
8O
PostPosted: Mon Apr 23, 2007 8:44 pm
My old one are off and on rbman's for now . His will be going on mine tomorrow .
