It is currently Fri Feb 20, 2026 3:15 am
 Post subject: fuse block
PostPosted: Mon Feb 12, 2007 7:55 pm
well i think i'm missing one but i don't know that much about the electrical part on these trucks
http://img481.imageshack.us/img481/1926 ... ockyn4.jpg
Thats what i have and my step-dad says thats it
BUT shouldn't there be somthing more??
I think it would of been on drivers side above the fender well
PostPosted: Mon Feb 12, 2007 8:43 pm
While I must admit it looks a bit naked, it has the correct number of fuses for a truck with only 2 headlights.
Mine is mounted on the drivers side and under a piece of clear (although scratched) plastic.
Good luck,
Eric Q.
My build thread.
PostPosted: Mon Feb 12, 2007 9:29 pm
so theres no other fuses for like the radio and stuff??
 Post subject: .
PostPosted: Mon Feb 12, 2007 10:05 pm
Radio probably had/has inline fuse.
but yeah, that's your fuse box, or what's left of it.
FIAA: Color Guard
PostPosted: Mon Feb 12, 2007 10:49 pm
well nothing but BAD words..
PostPosted: Tue Feb 13, 2007 1:14 am
The radio uses one of those fuses. If you haven't yet purchased a shop manual for your truck I'd highly recommend it. They can be found on e-bay regularly for less than $10.
And in the mean time, reference the wiring diagrams that Ben has posted in the Information section.
Eric Q.
My build thread.
PostPosted: Tue Feb 13, 2007 2:18 am
there is a wiring diagram in the information section on the front page of luvtruck.com it well tell you every wire on the truck. and what fuses are hoked up to what device. If you do not know how to read it have some one teach you it will save you tons of time in the long run.
her is the link to the wiring diagrams
http://www.luvtruck.com/Information.htm
Current Fleet
pics
 Post subject: Fuse block
PostPosted: Tue Feb 13, 2007 8:53 am
Here's a couple of photos.
Image Image
'78 1.8L 4-speed Fleetside
Image Image
 Post subject: Top
PostPosted: Tue Feb 13, 2007 12:16 pm
here ya go
FIAA: Color Guard
PostPosted: Tue Feb 13, 2007 5:58 pm
hmm so maybe someone just moved mine
thanks guys
 Post subject: Wiring
PostPosted: Tue Feb 13, 2007 11:30 pm
http://www.wiringproducts.com
has what you need. They look a like what came stock in the truck with a good solid base and a clear cover for about ten bucks.
 Post subject: Re: .
PostPosted: Thu Feb 15, 2007 12:37 am
79-Luv'r is correct. There is a fuse holder mounted directly on the back of the radio. I just received my new radio from ctmandu and it is almost perfect. Thanks ctmandu.
My build thread.
