It is currently Mon Jun 08, 2026 6:41 pm
 Post subject: Doors
PostPosted: Mon Feb 12, 2007 7:16 pm
Anyone ever "repin" their door hinges? Mine have a pretty good amount of play in them, would like to replace... short of finding new set of hinges.
FIAA: Color Guard
PostPosted: Mon Feb 12, 2007 8:00 pm
My set were messed up when I replaced my doors, so I just got every set of hinges they had in the yard (3) and I tried them all and found the best ones. . . not a great solution. I would love some info on re-pinning. Good luck man !
-Austin
PostPosted: Mon Feb 12, 2007 9:05 pm
the top hinges are able to go on either side the bottom might work but it would be upside down and to me looked like it might not work right... i have got right hand top hinges and put them on the driver side and my door didn't sag any more
PostPosted: Mon Feb 12, 2007 9:27 pm
Cat: How do you get to the top hinges ? I only replaced the bottom ones and my doors sag a bit, would I need to remove the dash ?
-Austin
PostPosted: Mon Feb 12, 2007 9:40 pm
LUV Rush wrote:
Cat: .... would I need to remove the dash ?
-Austin
please say no, please say no... :?
FIAA: Color Guard
PostPosted: Mon Feb 12, 2007 9:42 pm
No. If you have the door open, there are two hinges in the jamb.
PostPosted: Mon Feb 12, 2007 9:47 pm
The bottom ones have to be removed by taking off that little door, or in a mikado's case, a little vinyl panel. The top ones have bolts coming through from the dash side, I will get under it tommorow and see if the bolts are visible, cause god help me I will not take that dash apart.
-Austin
PostPosted: Mon Feb 12, 2007 9:50 pm
ok on the bottom hinge inside the cab is the little plate you had to take off to get to the hinges from the inside well there it also one on top , they have 1 small screw in the top of then they are shaped like a god house ... the dash does not come off.. ok i had to remove my kick panel for this....ha ha, lucky i had it off , wireing the dome light and switch today so good timing
PostPosted: Mon Feb 12, 2007 10:03 pm
Awesome, thanks for the pic Cat. . . you're right I wonder why the little doors look like God houses :) Some hidden meaning in LUV hinges ? Hehe ! :twisted: Man, I am a horrible person.
-Austin
PostPosted: Mon Feb 12, 2007 10:05 pm
sorry was to be DOG house
 Post subject: .
PostPosted: Mon Feb 12, 2007 10:08 pm
Thanks for the pic TAC...er, I mean CAT :D
FIAA: Color Guard
PostPosted: Mon Feb 12, 2007 10:13 pm
my brain is right but my fingers cant spell worth s@#t.. anyway hope that helps
PostPosted: Mon Feb 12, 2007 10:42 pm
. . . One nation, Under Dog. . . errr. . . yeah :)
-Austin
PostPosted: Mon Feb 12, 2007 10:49 pm
My doctor says I suffered no drain bamage. :silly:
It's just a little lysdexia. (dyslexia).
PostPosted: Tue Feb 13, 2007 12:26 am
it is possible to rebuild the hinge. the weak link is the plastic bushing that wears out over time. after that is gone you have metal on metal with no bearing surface. the pin can be driven out. best done in a press of some type, hydraulic or arbor. one side has splines on it and the other side is smooth. drive it out towards the splined side. i found a K&S brass tube that was the perfect size to shim the hinge pin. I also added a brass washer to take up the slop from the missing plastic bushings.
Current Fleet
pics
