It is currently Mon Jun 08, 2026 8:14 pm
PostPosted: Mon Feb 12, 2007 4:45 pm
this one, it takes 3 bolts to get it on and a O-Ring.
PostPosted: Mon Feb 12, 2007 5:13 pm
that looks lik eit what ever it is lol
92 gmc on 35/12.50/15
81 luv on 31/10.50/15
PostPosted: Mon Feb 12, 2007 5:36 pm
Coasting valve solenoid.
PostPosted: Mon Feb 12, 2007 9:41 pm
Maybe I can help here. The octagon shaped thing with one wire is the fuel cutoff solenoid. It shuts off the idle circuit so the engine will stop quickly when the key is off. It just unscrews from the carburator. The other round thing with two wires is the coasting richer solenoid. It is attached with two or three screws. This is an emission control device. It opens and lets in additional fuel only when you are coasting in 3rd or 4th gear like down a hill or to a stop. This causes the engine to burn cleaner while coasting, in theory anyway. It closes when you push in the clutch or the transmission is in any other gear including neutral. It should not affect the idle as it is closed then anyway.----hope this helps.
Users browsing this forum: No registered users and 61 guests
