It is currently Mon Jun 08, 2026 6:57 pm
 Post subject: Clutch Cable
PostPosted: Sun Feb 11, 2007 4:46 pm
Hey, I plan on replacing my clutch cable tomorrow evening. I was wondering if there were any tips to make the job go smooth. It looks pretty straight forward. I replaced my collector gasket this weekend and noticed that two strands on my clutch cable were broken. Figured I better take care of that now, before I am stranded somewhere. Thanks for all the info!
PostPosted: Sun Feb 11, 2007 6:21 pm
i havent changed one before but let us know how it goes :) good luck
PostPosted: Sun Feb 11, 2007 8:38 pm
I can't think of any. It's pretty easy.
PostPosted: Wed Feb 14, 2007 7:20 am
Did you do the cable already? I was removing the engine and trying to get the cable off the fork lever, and I couldn't. I ended up leaving it on. Now that the engine is off, I can slip it off the fork very easily, because the motor mount is out. I would suggest if you have a problem removing it from the shift fork, try supporting the engine with a block and removing the motor mount on one side. Of course if you remove the cable from up top first this would be unnecessary.
Like Aaron said, let us know...
'78 1.8L 4-speed Fleetside
Image Image
