It is currently Tue Jun 09, 2026 12:15 pm
Post new topic Reply to topic  [ 523 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26, 27  Next
PostPosted: Tue Feb 06, 2007 4:11 pm
It was the right time and I jumped on it. My pleasure to be able to give back some benefit to others, as others have helped me too.
The head was done by Pacific Auto not so long ago with new Fel-Pro valve stem seals and pressure tested. They cleaned it again this past week, then gave me the opportunity to keep my costs down by dismantling and reassembling the rocker arms and shafts after they hot tank them to get all the sludge out that was created by the recent bearing meltdown. Well we're gonna do it the best I know how this time around, and by golly it ought to work.
I'm planning to go get an engine hoist tomorrow. I can't depend on others to bring me one and I need it several times. I want my own so I don't have the stress of meeting someone's deadline, so I'm gonna get it.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Tue Feb 06, 2007 6:33 pm
FullaLuv wrote:
There was some discussion on the filter before, but this is my thought so far. The Fram oil filters are not good quality, and I'm going for a Purolator. I'm basing that decision on advice given by my neighbor Jeff. I plan to have him help me with the engine assembly, and he has told me that he read a consumer's report about a comparison test done with lots of different filters. Based on filtration and flow, the Fram filter was always the worse, while the Purolator was the best. Jeff said he proved it to himself when he changed a filter on his Ford pickup which used to take a minute and a half to quiet down after starting with a Fram filter, and then went to Purolator after reading the article. He said it was quiet immediately upon starting. I would venture to say the Fram "Tough Guard" oil filter that I used probably didn't help the situation in my failed engine either. It probably helped to impede the flow.
If I ask him again where the article was, I'll let y'all know.
I also want to say that if we were supposed to fill the oil filter before installing it, why wouldn't the filter manufacturer instruct us to do so? One thing I know is that air compresses, and fluid does not. If the filter is installed dry, the air might allow an easier initial fill and flow through than fluid such as oil, even though it's designed for oil flow. Having said that you might even say pre-filling an oil filter could prevent the flow! I doubt it though.
I've heard of the teflon they put in frams messing up some motors.
PostPosted: Wed Feb 07, 2007 9:38 pm
I got the parts from the two hot cold water valves, and decided to tear the one Catman gave me apart to see what it looked like. I found the parts inside were in better condition than mine, so I swapped the parts around, and I might have a working valve together now!!!
I went and got a foldable engine crane today. Put it together. I also got a load leveler. I will use it tomorrow to pull out the engine from my LUV, and then practice mounting it on the engine stand. My goal is to be ready when the block is here from Pacific Auto Machine. I want to know exactly where I'm mounting the bolts and this engine crane is going to make it all better. No more he-man antics and dropping the engine. Then it's going to be assembled with care. I got Plastigage today too. The pistons, bearings, and gaskets are arriving tomorrow. I ordered at the store with the PartsAmerica prices! The machine shop will get my pistons on Friday, then the work should be done sometime next week.
Image Image
Image Image
Image Image
Image Image
PostPosted: Wed Feb 07, 2007 11:39 pm
Hi John or anyone,
one more engine question. the crankshaft pulley bolt. Is it regular or reversed threads. I am trying to get mine off so I can replace the front seal but no luck. Any tips on breaking that bolt fee. Help thanks
Current Fleet
pics
PostPosted: Wed Feb 07, 2007 11:54 pm
Put the LUV in high gear, and have someone stand on the brake for you while you turn the bolt counter-clockwise. I did it with a block of wood wedged in the crankshaft, but that was this last time when I was not worried about the crank, cuz it's toast already. The first time I did it, I had my wife stand on the brake as I described. Use at least a ½" breaker bar w/a 15/16 or metric equivalent. When you get the bolt out and you're removing the crankshaft pulley and harmonic balancer, don't get any dirt falling in the front cover! I would clean it above there first. Pop out the seal, and replace it properly!
Keep it straight!
Image Image
PostPosted: Thu Feb 08, 2007 12:37 am
Ah the old wife on the brake pedal trick. I am usually alone but I got her out of the house in her PJ's and it worked. thanks john
Current Fleet
pics
PostPosted: Thu Feb 08, 2007 5:55 am
PITA Old Fart
Cornwell, Matco, and Snap-on all make a flywheel holding tool that you can use by taking off the flywheel inspection cover on the back of your engine, then hooking the point of the tool into the teeth of the flywheel and then catching the flexible arm connected to the tool into the teeth too...or by hooking the other type tool on the edge of the flywheel where the teeth are.
Then you can brace the tool on the floor to prevent the engine from turning.
Here's what the two I have look like:
This prevents putting any strain on your drivetrain and your brakes that could cause any problems plus makes it easier to do by yourself...and is a helluva lot easier to use to keep your engine from turning over when you don't want it to.
I think I paid like $10-$15 for each...but that was a few years ago....but I have used them a lot.
Just my $.02 worth...
PostPosted: Thu Feb 08, 2007 2:47 pm
Looking good FullaLuv. You keep buying tools and you'll have a full blown engine shop before long. You got that engine out yet?
PostPosted: Thu Feb 08, 2007 7:26 pm
Got it out, yep! I took it out and some things apart. The legs were too spread apart to get through my shop door! I had to fold one up, but it worked! :D
Image Image
Removing the engine/The transmission input shaft and the clutch fork
Image Image
Hanging over the workbench/Pressure plate and clutch plate
Image Image
Flywheel/Signs of overheating
Image Image
Debris in #3 main bearing. It was full of sludge, top and bottom/G180
Image Image
Image Image
PostPosted: Thu Feb 08, 2007 9:26 pm
Another trick for the dampener bolt i have used is to get your wrench on the frame or the ground and hit the starter (spin the motor over for thoughs with a sense of humor)If that don't take if off it ain't coming off(wana bet)I gots a BFH as last resort. 8)
PostPosted: Thu Feb 08, 2007 9:30 pm
i had to do that once on my austin healey i had
PostPosted: Fri Feb 09, 2007 12:11 pm
like the cherry picker out of curiousity how much did that run?
cool cool
James
PostPosted: Fri Feb 09, 2007 3:29 pm
PITA Old Fart
Nice pictures John...but a big paper sack with two eye holes would improve them greatly.
BTW...how many pounds does that big wide-angle lens weigh that you have to use to get your big butt and your stuff both in the same picture?
J/K...:lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Feb 09, 2007 6:12 pm
I see John that you are a person of Harbor freight appreciation. I was there this morning and bought one of there hyd. pipe benders.Just so you know i have the same leveler in the garage. Your progress is commendable keep up the work you will be on the road in no time. Heres to ya :wink:
PostPosted: Fri Feb 09, 2007 10:42 pm
I got a lot to say today. I might not say it all cuz somebody might want to put a muzzle on me. They're already thinking of putting a bag over my head! Well photos can be joined with software, and I use Arcsoft's Panorama Maker to join photos. My avatar is two photos that were subsequently resized to 150x150 pixels.
This morning I went to pick up my new pistons and take them in to the machine shop for them to put on the rods. I also picked up the bearings, thrust washers, a new head gasket, pilot bearing, clutch throwout bearing, and chrome piston rings. I took in the rocker shafts which I had rubbed for some time with the green stuff, but Ted at Pacific Auto Machine said they weren't good enough and gave me some emery cloth strips to do it better. I picked up my engine top cover, and oil pan all cleaned up and ready for painting. Really clean! I also got the front cover cleaned, and the oil pump parts they checked out and recommended. I discussed breaking in the new engine, and was told there would not need any breaking in since there was no new camshaft. I discussed the oil pump with Ted and he said they will loan a pressure pump to me for priming the oil galley. I painted the top cover and the oil pan with hi-temp paint, and installed the oil pump into the front cover. Some of the parts are hanging up for staying out of the way. I got started on the rocker shafts, then my wife called me in for her homemade pizza.
Image Image
Image Image
Image Image
Image Image
Image Ham and pineapple pizza, made from flour, yeast, olive oil. tomato paste, & mozzarella cheese.
Image Image
PostPosted: Fri Feb 09, 2007 11:33 pm
PITA Old Fart
Hey...that pizza and you have the same shape...lol
PostPosted: Fri Feb 09, 2007 11:34 pm
I'm a comin' down there to get ya! LOL
Image Image
PostPosted: Sat Feb 10, 2007 6:47 am
Johnny Boy! Hows it going I have been MIA due to the loss of sight temporally. I got a nice piece of metal in my eye and it decided to rust in there. The docs had to drill it out it was lovely! Then it took until yesterday just to get a follow up eye examination and more contacts. Looks like you have been busy, Have a new cherry picker I see, how much did that thing run ya? So your gonna start up a Isuzu engine shop or something? Hey I need that fender emblem off your peg board! :lol: Got the old engine out eh. Those old bearings look lovely :? Nice pics, as always. That has to be one of the cleanest oil pans that I have ever seen that wasn't new. Glad to see such progress. Well I am off to the shop maybe I can catch you later on today.
 Post subject: LUV Emblem
PostPosted: Sat Feb 10, 2007 8:13 am
I like my LUV emblem too. It's the same one as is on the LUV truck, and right now it's not on the peg board. I fastened it to the light over the workbench. I think Tazman might have what you need, I suggest you give His Ugliness a buzz.
I hope you don't have to get a glass eye. I saw a program a few days ago on how they make 'em. They pour a soft compound into the eye socket, and let it harden, then take it out, and go from there. They go through several processes then end up with a painted-on iris and pupil. It's covered in acrylic and polished. When they get it all done, it's conformed to the musles in the eye socket so that the artificial eye moves exactly the same as the one you still have left. If you're still reading this you better be warned. Two strikes and the sight will be gone; even if they drill a hole in your forehead and give you a third glass eye, it won't bring back the eyesight. WEAR THE FRIGGIN' EYE PROTECTION!
Image Image
PostPosted: Sat Feb 10, 2007 9:26 am
Been there and done that. Man i know it ain't no fun :( When you get metal in your eye you need to go to the doctor asap before it has a chance to rust. I learned this the hard way also. Hope that eye gets ok.
That advice from Fullaluv about eye protection is good advice for everyone here.
