It is currently Tue Jun 09, 2026 7:01 am
 Post subject: runs like crap
PostPosted: Fri Feb 02, 2007 7:43 pm
ok what does it mean when you have little bubbles coming out between your head and your block and there is no water in the 710 i mean OIL lol sorry old joke and all is good but not good is it just luck that maybe just do a head gasket and i might be that lucky and do a compresion test ok all and any help will be alot of help thanks
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri Feb 02, 2007 8:56 pm
Seem like a blown head gasket. Do you have white smoke coming out the exhaust.
PostPosted: Fri Feb 02, 2007 8:58 pm
PITA Old Fart
Sounds to me like a head gasket leak.
BTW...Not every head gasket leak gets coolant in the oil or oil in the coolant...sometimes it just leaks coolant out of the head into the engine compartment and sometimes into the cylinders... sometimes cylinder pressure can leak into the oil or coolant...and sometimes it just leaks oil into the engine compartment or into the cylinders too...it all just depends on what part of the gasket failed.
PostPosted: Fri Feb 02, 2007 9:50 pm
My wife used to have a 78 celica that had a blown head gasket. It leaked into the combustion chamber and just made steam. I just kept adding water and drove it like that a long time until one night coming home from work it started missing real bad at a light and made a lot of steam. I just kept it revved up and drove it home.
The next day I pulled the plug ( I tried #3 first for the hell of it and by luck that was the one), and hit the starter. It was like a super soaker! Squirted across the yard!
PostPosted: Fri Feb 02, 2007 10:52 pm
thats what i was thinking but i think i'm on good side of luck i hope i pulled all spark plugs and they still look good so i think it is still the head gasket so i am going to have the head done and gasket and see what comes of that and the go from there and thanks lot to all you guys i will still check in time to time :cry: :cry: :cry: :evil: :x :( :?
dangerous-toys4life
75 k-5 2x
94 king cab
