It is currently Fri Mar 20, 2026 11:50 pm
 Post subject: lift, blocks in rear
PostPosted: Mon Jan 29, 2007 7:00 pm
i was planning on crankin my bars 2.5 inches, and puttin blocks in the rear, my question is, does anybody have blocks in the rear, or do u use extra leaf, or what?? Also I plan on a 2" body lift. I have a 79 4x4 with 28" mudders and this thing is a beast, my wife has a jeep with 4 inch lift and 33's and I can go where she does anyday! I love my luv-
PostPosted: Mon Jan 29, 2007 9:08 pm
The springs are under the axle on the LUV so blocks lower instead of lifting. For that the amount of lift you're talking, go for longer shackles and/or adding a leaf. You can reweld the spring perches and put the axle below the springs but that would get you around 5-6 inches of lift and you can't crank the torsions enough to match that in the front.
PostPosted: Tue Jan 30, 2007 8:40 pm
what size shackles do you recommend for a 2-3" torsion crank- tahnk dude
PostPosted: Tue Jan 30, 2007 9:06 pm
Shackles give half their added length in lift. So if you use shackles 2 inches longer than stock, the truck will sit 1 inch higher.
That said, I'm not sure how much is too much shackle really. My 4x4 had springs that had been rearched or were from a different vehicle with stock shackles. Somebody else want to chime in here with more experience, how much is too much shackle? For 2.5 inches you'd need to add 5 inches the length of stock shackles, which seems a tad long to me.
PostPosted: Wed Jan 31, 2007 12:52 am
Blocks = BAD :lol:
that being said, try using a longer shackle or finding a lift spring out of a toyota or something else with a little more arch.
I noticed you're in Washington. Where in WA. are you??? If I'm close enough maybe i can help you out a little 8)
PostPosted: Wed Jan 31, 2007 6:57 pm
sequim, port angeles area
PostPosted: Thu Feb 01, 2007 12:47 am
I rebuilt my leaf pack by adding a couple 3/4 ton chevy leaves, it rearched them enough to give me 3 or 4 inches of lift.
Be careful with tall shackels, you can change your pinion angle too much and you could start eating U-joints.
Looking for that special LUV.
PostPosted: Thu Feb 01, 2007 1:15 am
ya, good point trooper, you could always correct it with some shims though if need be, maybe check your pinion angle before you get too involve and try and re match it when you're all done lifting it.
PostPosted: Thu Feb 01, 2007 8:09 pm
That is sort of what I was thinking. Longer shackles are ok to a point, but not to extremes. I had not thought about the pinion angle being the reason, but would be the reason not to go too far with shackles alone.
I was thinking about using the springs out of an Isuzu trooper when I get around to building up my 4x4 LUV. I'd like to swap in an Isuzu 12 bolt rear anyway, and with the heavier Trooper I figured that should be good for an inch or two of gain.
PostPosted: Fri Feb 02, 2007 2:46 am
Banishment Pending
Wow, I was thinking of the same thing...and come to find out that '88 Trooper springs will provide some lift (after measuring them I guess about 2" or so) and also swapping in a 12 bolt or a D44 out of a 91-97 Rodeo
