It is currently Mon May 25, 2026 6:46 pm
 Post subject: new how to's
PostPosted: Tue Jan 30, 2007 10:26 am
well i added how to put a tilt colunm in the luv and how to do a targa top . added them to the link below the WWW
PostPosted: Tue Jan 30, 2007 1:53 pm
Sorry but I could not find it.
PostPosted: Tue Jan 30, 2007 4:14 pm
5 down for the luv tilt column... and 13 down for the targa top
http://www.chevyluv.zoomshare.com/1.shtml
PostPosted: Tue Jan 30, 2007 4:35 pm
This had me confused also, I was thinking WWW meant his yahoo link.
PostPosted: Tue Jan 30, 2007 5:19 pm
ctmandu:
Did you do a tilt column on your truck? Wonder why they say to use a van column? I must have read this years ago, or something else said to use the van column.
I don't see why something else would not work.
Good info, thanks for posting.
Richard
PostPosted: Tue Jan 30, 2007 6:03 pm
Maybe is was because van columns are generally cheaper and maybe easier to find? Just a guess. I to have seen this and have thought about doing it but haven't ever found a straight shift column (I want to have floor shifter, Not 3 on the tree) without the key. Thanks for the pics and literature cat I have been debating on what would be needed to do this myself.
PostPosted: Tue Jan 30, 2007 8:44 pm
PapaG wrote:
ctmandu:
Richard
as for the van column it is usually because the are shorter
mine is ready to go but not in yet , i used a 63 chrysler 300 column cut my luv column(extra one) mated the 2 together used the luv floor mount cut to fit the chrysler by using a reducer for an exhaust to fit both columns together.. had to have the luv column machined down a little to fit inside the 300 column
this pic is the one i have but doesn't show the exhaust reducer it was taken before i bought it
PostPosted: Tue Jan 30, 2007 8:47 pm
I had a tilt out of a Camero but have sense returned back to stock.
PostPosted: Tue Jan 30, 2007 8:50 pm
thats why i went to and early 60's chrysler beside the chryslers had the auto on the dash (push button) and it was at a sweet price not high like the early chevy
PostPosted: Wed Jan 31, 2007 12:17 am
So I take it you have ran into the same thing then.
So you used one out of a old Chrystler, I wounder if a column out of like a 58 Chrysler Imperial because there is a junkyard close by, next door to the shop really. Maybe it still has the column in it.
I have always thought about doing it but never thought it was worth what ididit and flaming river where asking. Which there prices are starting to come down a little.
