It is currently Sat Jun 13, 2026 12:32 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Tires
PostPosted: Tue Nov 07, 2006 7:14 pm
Whats the bigest size tire that will fit on a stock 4x4 Luv
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Nov 07, 2006 7:28 pm
That is a loaded question Chavy.
There are several factors to consider like the rims. How wide are the rims you have or are you going to get a new set? What is the off set of your rims, that makes a difference due to tire rub on the body or suspension. I would say to visit a tire store and let them have a look at your rims and they could answer your question since they are looking at your truck.
PostPosted: Tue Nov 07, 2006 8:13 pm
I've got 215/75R15 tires on my stock height 79 4x4, but that is with stock 15 inch 86 Trooper wheels. The trick really is to find wheels with enough backspacing, I had previously tried the same size tire on some wider wheels that stuck out quite a ways and they rubbed the fender just sitting still.
PostPosted: Wed Nov 08, 2006 12:03 pm
Banishment Pending
As 800 said the trick is backspacing, i found that a 235x75r15 would fit on my truck with no rubbing, they where on stock Isuzu Trooper LS rims which are 15x6 with not much backspacing. I know that when i first got my 215's (before the body lift and SL) that they did rub a little when I made sharp turns, different rim backspacing would solve that problem...and i would go with stock Isuzu Trooper rims ( they work as far as i know, and the wider 15x7 "Snow Flakes" look cool)
PostPosted: Thu Nov 09, 2006 3:24 am
I Believe RedLuv80 Had 31 12/50's On His 1980 4X4 But Thats With The Torsion Bars All The Way Tightened And 3" Shackles. Close Enough To Stock Right?...lol Wheels and Back Spacing Is The Major Factory As Previously Stated.
PostPosted: Thu Nov 09, 2006 10:28 pm
so would 29s fit
79 4x4 1.8 liter
PostPosted: Thu Nov 09, 2006 10:33 pm
Should. Not Sure My 4x4 Has Like 26's Or Whatever Is Factory.. My Poor Little Raped 4x4...It Pink To Make It Worse. LOL I Need To Drag That Thing Out Of The Woods and Steal Some More Parts...lol Poor Truck
PostPosted: Thu Nov 09, 2006 11:12 pm
Banishment Pending
Yes 29's will fit, like said before you'll have to mess around with rim back spacing to get the right fit (try different rim back spacings, more than likely though stock Isuzu rims will work the best)
PostPosted: Sat Jan 27, 2007 4:10 pm
where kind i find 15 in Isuzu rims
79 4x4 1.8 liter
PostPosted: Sat Jan 27, 2007 4:17 pm
Here is a couple aftermarkets off ebay.
http://cgi.ebay.com/ebaymotors/15-inch- ... dZViewItem
http://cgi.ebay.com/ebaymotors/15-Inch- ... dZViewItem
You should be able to find some stock ones like on a rodeo or trooper pretty easy.
PostPosted: Sat Jan 27, 2007 9:18 pm
so would the ones from less swab be any good
79 4x4 1.8 liter
PostPosted: Sat Jan 27, 2007 9:27 pm
well be carefull of les schwab make sure that the back spacing is correct I had a set that dug into my a-arm it took me a while to figure out that noise.
PostPosted: Sat Jan 27, 2007 10:34 pm
or can any of u guys tell me if theres a place that makes a 29 tire that will fit a 14 in rim
79 4x4 1.8 liter
PostPosted: Thu Feb 01, 2007 7:35 pm
any one I relly dont wana have to buy a 15 in rim
79 4x4 1.8 liter
PostPosted: Thu Feb 01, 2007 7:55 pm
other than a super swamper 28 or 27" they don't really have a lot of options for 14" rims, trust me when i say this, you WON'T regret going to a 15" rim, once you do i gaurantee you will never go back, all the options in the world for tires are in the 15" rim size :wink:
"I'll take 'The Rapist' for $1200 Alex..."
"That's 'Therapist' Mr. Connery"
PostPosted: Thu Feb 01, 2007 7:59 pm
http://www.4wheelparts.com/PDT65087.aspx
there ya go, that's the biggest size in a 14" you can get through interco...
PostPosted: Tue Feb 06, 2007 6:58 am
I GOT 31/12.50/15 MICKEY THOMPSON MT'S ON 81 4X4 WITH A 4 INCH BODY LIFT WORK GOOD FOR ME :)
PostPosted: Fri Feb 09, 2007 1:59 pm
I got 28" mini mudders with no lift on a 79 4x4, and im pushin it----
PostPosted: Sat Feb 17, 2007 2:15 am
now if u lived in oregon i coulda hooked ya up with 4 15" wheels white or chrome for 50 bucks. but now they're gone...
muddy luvs are like sex. ya just cant get enough of either.
PostPosted: Fri Apr 06, 2007 11:07 am
now would a stock 6 lug chevy rim have the right back spacingto not rub cus I am going to tighting up the Torsion enough to clear the fenders if they fit
79 4x4 1.8 liter
