It is currently Sat Jun 13, 2026 9:40 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: engine video
PostPosted: Sun Jan 21, 2007 2:44 pm
http://video.tinypic.com/player.php?v=2nqe1jo
the original is better quality, everytime I upload it it doubles the size, and messes up the quality. anyway, can anyone hear a tap or knock, over the exhause leak.
PostPosted: Sun Jan 21, 2007 11:03 pm
Not really
it almost sounds like our 2 cylinder diesel but not as loud
On the search for another Luv Machine
PostPosted: Sun Jan 21, 2007 11:33 pm
did this just hapen and has the smog stuff been removed? if so look for the 4 plugs for the smog rail sound like one came out... mine has done this once and my sons has also... makes it sound like a tractor
PostPosted: Sun Jan 21, 2007 11:39 pm
whats wrong with it sounding like a tractor
PostPosted: Sun Jan 21, 2007 11:48 pm
Tractors are supposed to sound like tractors. LUVs are supposed to sound like lawn mowers. :lol:
(I better talk nice. I'm driving mine to work tomorrow and it might get mad at me and break down) :lol:
PostPosted: Mon Jan 22, 2007 12:18 am
Just sounds like a normal exhaust leak to me.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Jan 22, 2007 11:07 pm
well i wana loud lawn mower....
might run 2.5 pipe just pass the door...
that way they'll know a Luv's coming and it might sound like i'm moving at the speed of light
"BRAAAAAAAAAAAAAAAAAAAAAAAAAA *backfire* BRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
PostPosted: Tue Jan 23, 2007 3:07 pm
Someone else removed the smog, I'll look for the smog rail, is it around where the pump was. someone drilled holes in the exhaust pipe just before the muffler, and I can feel a small leak around the donut, I think.
It finally unthawed from the ice storm, I removed a 4ft 2in thick sheet of ice off the hood sunday..LOL
PostPosted: Tue Jan 23, 2007 5:12 pm
8O wow i'm glad i'm in arizona..
It snowed in Phx but no snow for me and i would like to keep it that way
PostPosted: Tue Jan 23, 2007 7:18 pm
this is where the usually plug them
PostPosted: Tue Jan 23, 2007 7:43 pm
dang u and ur fancy everything!
i'm paint my valve cover soon
what paint works best?
PostPosted: Tue Jan 23, 2007 7:56 pm
not sure what works the best ... any of the high temp paint would work great or powder coating would also.... the valve cover was just a normal silver with a thin red coat over it to give it a candy paint or cherry paint look
PostPosted: Tue Jan 23, 2007 8:19 pm
I'll check these out, I thought that was for fuel injection and someone put on a different head.:) they bent the tubes over on mine, I'll check for leaks, what would you use to replace what they have done, what kind of bolts?
Quit posting pic's of your engine, I'm getting wood.....
PostPosted: Tue Jan 23, 2007 10:05 pm
The easiest way is to unscrew the fittings for the tubes, wack the tubes off and chuck them and the whole damn rail in the trash with the rest of the worthless smog crap, thread the centers of the fittings with a tap, and then beat feet down to the hardware store and get a set of hardened allen head bolts and copper washers.
Then screw the fittings back in the holes in the head, and use the allen bolts and copper washers to plug them up.
That way it isn't noticable...and you have a nice tight permanent seal.
BTW...when you start yanking off all of your smog crap...make sure that if you pull out the ugly studs left sticking out everywhere on the head...that you use copper washers on the bolts you use to replace them...or you will have trouble getting them to to seal...and you might just create a small but messy oil leak.
PostPosted: Tue Jan 23, 2007 11:42 pm
like tumwatertaz said.. i cut the rail off then used a 1/8 npt tap and replaced with plugs. and you cant see them
PostPosted: Tue Jan 23, 2007 11:44 pm
That is one clean and neat engine bay ctmandu. I like it! :smt023
PostPosted: Tue Jan 23, 2007 11:47 pm
hmmm it prutty
PostPosted: Wed Jan 24, 2007 7:42 am
Gorgeous engine! I'd be doing good to get mine looking half that nice.
I enjoyed the engine video. I don't pick out anything abnormal, but that's me.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Jan 24, 2007 4:18 pm
I used Chromillusion paint on mine after I sanded it down to bare, shiny metal. I also did my breather cover to match, even though most of the time it isn't on the truck.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Thu Jan 25, 2007 2:05 pm
I fired it up today, and checked the bolts and none were leaking, but the donut was, I think I will take it into the muffler shop and have them replace the donut and fix the pipe where the other owner drilled holes in the exhaust pipe. the say the best way to take off the nuts from the exhaust manifold is to heat them cherry red and then burp them out with a impact so they don't snap off. I wish a header wasn't so high, i'd just get one.
Users browsing this forum: No registered users and 56 guests
