It is currently Wed Mar 18, 2026 10:13 am
 Post subject: Picked up a Buick V6
PostPosted: Thu Jan 18, 2007 2:20 am
The other day I was looking through the ads and found this 231 V6 for the perfect price. :shocked!: Free!!! :shocked!: Im considering dropping this in my '78 but before I do what kind of fuel milage are you guys getting with these in your luvs?
Heres some pic's...
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Jan 18, 2007 7:45 am
Get the 200R4 to go behind that motor and you will get better milage than you will with the stock 4 banger.And if you bwant a little more out of it then get the 2.5 converter off a S10 and that will give it a little more stall and rev. quicker.
PostPosted: Thu Jan 18, 2007 8:42 am
If you're concerned with fuel mileage, dont bother with the swap. Why upgrade to a bigger motor if you have to nurse it around to conserve fuel?
If you want to build a truck that has enough power to get in and out of trouble, then go ahead and put it in. The performance gain offsets any mileage loss.
Everyone thats done a swap doesn't mind the economy loss. It becomes more of a fuel tank being too small for the engine problem.
That free motor... Does it need a rebuild? Do you have a 2 bbl, non emission carb for it?
You'll need a different distributor for it, one with a vacuum advance.
PostPosted: Thu Jan 18, 2007 10:13 am
I am getting around 6 MPG with mine!!! 8O
PostPosted: Thu Jan 18, 2007 2:58 pm
Haven't been able to omeasure yet - but it's not great mileage. The speedo and odo are off - speedo says 55 when doing ~35... have to look into fixing that soon too...
PostPosted: Thu Jan 18, 2007 11:12 pm
I checked the compression and looked at the oil it seems to be a good motor. I turned it over by hand but I'll find out once I get a new intake, carb and a vacum advance distributor.
I guess I'll just keep it for another project then. Fuel was cheap when I built my V8 luv but when I finished the swap gas prices went up. I thought the v6 would get a little better milage but oh well atleast I still got the 5-speed lol.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jan 19, 2007 12:21 am
My V-8 powered LUV gets great mileage, I have not put fuel in it for 3 months now! 8O The people are right, you will not get better mileage with the 6 but I would assume better reliable power plant.
PostPosted: Fri Jan 19, 2007 7:49 am
What is with the vac adv. You don't need unless you are trying to squeeze the last mpg out of your motor as that is what it was for hell i take the vac adv off of my dists and set the mechanicals to what i want and have no problems.The Buick V6 is a good little motor and will give better milage than a V8 (duh).Suggestion get a 4V manifold a 390 or 450 carb. tune the motor with a overdrive trans (a T-5 would be fun) and you will do better than the stock motor.
PostPosted: Fri Jan 19, 2007 1:59 pm
This is my first buick motor and all I can find are T-5's with the Chevy bellhousing pattern none with the B.O.P. pattern. Do I need to look for that special bellhousing or look for an adapter plate?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Jan 19, 2007 6:06 pm
The bellhousing in my trk is a BOP engine. Depending on the wrecking yards you should be able to find one you might even find a cable one in a Buick skyhawk(monza clone) don't give up cause that would be a real fun ride.(theres always evil-bay)
PostPosted: Sat Jan 20, 2007 11:54 pm
Ok I'll have to look out for one of those next time Im at the junkyard. Thanks for your input everybody.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Jan 21, 2007 12:32 am
look here maybe this will help
http://www.downeyoff-road.com/EngineCom ... /index.htm
PostPosted: Sun Jan 21, 2007 10:20 am
The thing about the distributor is that it's computer controlled. There isn't even a mechanical advance. This makes it useless to try to make it work.
Finding an appropriate Buick even fire distributor in a junkyard is iffy at best but you could luck out there. Mallory and MSD make new performance units but that's a few hundred bucks. They come with vacuum advance so you might as well utilize the option since you shelled out all that money on a free motor.
Fro street use, it's always a good idea to run vac advance, you'll only benefit from it. Even if you see track time on a motor and you only rely on mech advance, you're still street drive for the majority of the time.
PostPosted: Sun Jan 21, 2007 4:09 pm
Found a couple of Buick bellhousings on E-Bay but i don't know how to get the address to transfer to here .One is on a site called Daves 4sp's i believe. They might be a little pricey but there are more around.
