It is currently Sat Mar 28, 2026 3:16 am
PostPosted: Mon Jan 15, 2007 9:52 pm
has anyone heard of putting coil overs in place of the shock absorbers with stock luv suspension? i noticed a guy in the pics place it looked like stock sway arms and stuff with coil overs. i need to get my truck lower in the front my torsion bars wont go low enough (4+4 to 2 wd conversion ) so i thought maybe i could put coils in to get more options short of spending alot of money like with mustang front suspension. also my rear suspension is getting coil overs so that would be cool to do the whole thing.
81 chevy luv 336 small block
01 dodge cummings
PostPosted: Mon Jan 15, 2007 10:02 pm
Mine has coilovers on the front, but it doesn't have the torsion bars now. That should get it down where you want it.
PostPosted: Tue Jan 16, 2007 1:27 pm
When I had my LUV I had bought QA1 coil overs and somebody on this site, who also has since sold his truck, sent me a set of top brackets to weld in the stock pockets. Part # 3855P shocks w/7-350 coils. You can buy some bolt on brackets from a circle track place or ebay just to get the placement easier and then give them a couple tack welds. The bottoms bolt in like the original shocks. Then you can ditch the torsion bars, cut off the brackets and even shave some metal off the shock towers around the edges to get rid of some weight up front. I dumped the pics I had of my truck and the other guys set up when I sold my truck. :roll:
PostPosted: Tue Jan 16, 2007 1:39 pm
luv4me was the other guys screne name. Maybe the pics are still here from his posts.
PostPosted: Tue Jan 16, 2007 7:22 pm
wow thanks guys thats what ill do. it will be sweet ill get those qa1 coils coming. maybe i can get it on the ground ha ha
01 dodge cummings
PostPosted: Tue Jan 16, 2007 7:29 pm
This brake thread shows the coilover set up on my truck somewhat...
http://forums.luvtruck.com/viewtopic.php?t=11939
PostPosted: Tue Jan 16, 2007 10:48 pm
Here a few I found, plus
luv4me
http://www.luvtruck.com/Gallery/AndyBryants76EaglePointOR/index.html
http://www.luvtruck.com/Gallery/TomHintzs76ScappooseOR/luv4.html
http://www.angelfire.com/tn2/xr50freekz/luvbuild.htm
LUV: 1980 Street/Strip
Email: skyedivr@yahoo.com
Web Site: http://www.angelfire.com/tn2/xr50freekz/luv.htm
Forum Name: luv4me
Notes: Always Under construction..... feel free to check my website out or email me with any questions.
PostPosted: Wed Jan 17, 2007 1:31 pm
That last link is how mine looked also as he was the guy that sent me the brackets.
PostPosted: Wed Jan 17, 2007 9:03 pm
so how do i know how long to order the shocks/ coils? big happy where is that part number from ?
01 dodge cummings
PostPosted: Thu Jan 18, 2007 1:20 pm
[quote="luvontherocks"]so how do i know how long to order the shocks/ coils? big happy where is that part number from ?[/quote]
Part # from end of the box they came in. I was told to use the short ones that luv4me used so I did.
PostPosted: Thu Jan 18, 2007 8:14 pm
ha ha i meant like summit jegs ? or do u know ?
01 dodge cummings
PostPosted: Thu Jan 18, 2007 8:30 pm
I don't know what the part number is on mine, but if you click on the threads in the above posts and, compare, the shock on my truck is shorter. When we fab a suspension, we make the top mounts to fit the shock we are going to use. As long as the compression and rebound are adequate, you can use whatever you find.
PostPosted: Fri Jan 19, 2007 7:31 am
http://store.summitracing.com/partdetai ... toview=sku
are these the ones? the part numbers pretty much match up
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Sat Jan 20, 2007 7:16 pm
sweet i ordered them i think thats better i wany to get the front done before i get the back done so its got a good ride stance. thanks for the help guys :D
01 dodge cummings
