It is currently Sun Dec 14, 2025 12:16 pm
 Post subject: Help! Surging 83 Nissan!
PostPosted: Wed Jan 10, 2007 3:06 pm
I just got an 83' Nissan 720 truck, it has a "Nap-Z" motor, and a stock carb. The truck won't stay running at idle, or when I bring the truck to a stop. When I driving down the road, and take my foot off the throttle to "coast" the truck surges real bad. When I got the truck the idle was turned up real high to keep the truck running, but it still died at stop signs.
Oh, and the fuel mileage sucks!
What I've done:
New cap, rotor, plugs new ones gapped at .0032 old ones gapped at .0040, wires, cleaned carb with spray cleaner.
What I'm gonna do at payday:
fuel filter, air filter.
Also I sprayed carb cleaner every where, and couldn't find any vac leaks.
Any Ideas?
Thanks,
KT-
Looking for that special LUV.
PostPosted: Thu Jan 11, 2007 7:20 am
On the bottom of the carb there is a couple of plugs side beside and kinda hard to get to but pull the plugs (12mm i think) and drain the float bowl if you can see watch what comes out.These plugs a access plugs to the jets ans dirt and water collect in there.If your carb dose not have these plugs then either pull the float cover or you may have to pull the top off.
PostPosted: Thu Jan 11, 2007 4:44 pm
I'll take a look, thanks.
