It is currently Sun Apr 05, 2026 2:54 pm
 Post subject: I screwed up today
PostPosted: Sun Jan 07, 2007 8:15 pm
After all the years I have worked on vehicles, I finally screwed it up, I feel so stupid and I am pissed, I have worked around aluminum heads along time, and it was a cool engine, I pulled a plug to see how the engine was burning fuel, and I should have washed that engine first, but after I checked it, I eased it in with my fingers, and cross threaded the damn thing, I have never done that before. So I hope I can fix it, with a steel insert. Either I crossed threaded or someone else did before me.
PostPosted: Sun Jan 07, 2007 8:50 pm
:cry: Sorry man.
PostPosted: Sun Jan 07, 2007 10:31 pm
A word of wisdom You should never put spark plugs in an alum. head without antiseize
 Post subject: aluminun heads
PostPosted: Mon Jan 08, 2007 12:33 am
TJ is absolutely right. 20 years ago we bought a new Subaru. After pulling the plugs and setting the gap, I followed the owners manual and lubricated the plug threads with 30 weight oil. The next time I pulled them, it took me 2 days to pull 4 plugs. Penetrating oil, tap the plug socket and weight a couple of hours, turn the plug a quarter turn. Start the sequence again. I saved the threads. Lucky me. Luckily I knew about antiseize compound before I bought my LUV almost a decade ago.
PostPosted: Mon Jan 08, 2007 12:48 am
damn cross threading urrrr!
we used never sieze quite a bit when I worked at a tire shop especially on semi trucks threads. made life easier on the next guy as well.
GOOD STUFF.
PostPosted: Mon Jan 08, 2007 1:39 am
Damn!
:oops:
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Mon Jan 08, 2007 10:23 am
don't worry everyone does it sum times
i admit it
i've done it
On the search for another Luv Machine
