It is currently Wed May 27, 2026 3:10 am
 Post subject: K&N Air Filter
PostPosted: Fri Apr 11, 2003 8:26 pm
I just ordered a K&N Air Filter for my 75 luv,will I feel a difference in power?If I take off all the smog crap will I get more power?Are there any other tricks to get more power? :D
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Apr 11, 2003 8:29 pm
i can't feel the horses but she runs smoother at higher speeds :D
PostPosted: Fri Apr 11, 2003 8:51 pm
The only power increase you'll feel when you remove the smog stuff is if you have sealed up any air leaks you may have had. It's not so much as a power increase as it is a corrective action of losing power thru worn out emissions crap. Do some testing to see if you have any air leaks. The K&N filter isn't going to be very noticable on a stock engine. Basicly, stock is stock. Getting the motor to breathe better and to get it to pump exhaust out better is always good to do. Uncork the exhaust system and you can feel a differance.
PostPosted: Sat Apr 12, 2003 9:10 pm
if you whant noticable power get a header and bigger exaust in it. When i did that it was night and day.
A K&N may get you another .5 mpg or something and make it run smoother.
PostPosted: Fri Apr 18, 2003 8:36 pm
OG Lifer
You need a weber 32/36 dgev. Thats what I have. It came with a chrome open element air cleaner with a k&n filter. My truck runs 10 times better. Even gets better gas mileage.
WATCH YOUR PIEHOLE!!!!!!
Users browsing this forum: No registered users and 59 guests
