It is currently Tue Mar 24, 2026 11:11 am
 Post subject: tranny swap
PostPosted: Fri Aug 16, 2002 9:06 am
OG Lifer
i have the stock 4-speed behind the stock motor. does anyone know if there is a five speed that will bolt right up into place? thanks
PostPosted: Fri Aug 16, 2002 8:44 pm
im not sure if it will work but,
i had a 87 (i think) izuzu impulse that had the same eng 1.8 (mine WAS turbo tho) with a 5 speed
but it did have a wet clutch whereas the LUV's had a dry clutch.
hope this helps
btw, someone kick my ass for selling that car for $500 after i blew the head gasket and warped the head.
how the hell did i know they were that rare.
ive been looking for another for a few yrs now.
PostPosted: Fri Aug 16, 2002 10:15 pm
call one of those japanese used engine places they have trans too and would know what has the same bolt pattern
PostPosted: Fri Aug 16, 2002 11:49 pm
OG Lifer
k thanx ill try both.
PostPosted: Sun Oct 27, 2002 9:12 pm
:wink: im not really sure about anything but i was wondering if the 83 to 87 camaro trans (5 speed) will work because im building a pretty peppy 283 to put into my luv and i just want to be able to stomp all of these little ricers around my town any help would be appreciated thanks guys
PostPosted: Tue Oct 29, 2002 5:45 am
:) Try castlemaine Rod Shop over here in Australia for your tranny swap.
Rod Hadfield has a large variety of bellhousing adaptors for anything imaginable.
http://www.rodshop.com.au/chassis.htm
If they dont have it they can usually make it. Check out the 55 Chev with the V12 merlin engine they're building to give you an idea.
PostPosted: Tue Oct 29, 2002 5:48 am
Whoops, Castlemaine Rod Shop also do O/S freight
PostPosted: Tue Oct 29, 2002 9:01 pm
OG Lifer
thanks ill try em
WATCH YOUR PIEHOLE!!!!!!
