It is currently Sat Jun 13, 2026 5:20 am
 Post subject: Luv Truck Specs
PostPosted: Mon Jan 01, 2007 9:54 am
Does anyone know the exact specs on a 1979 Luv truck...length, weight, etc.? I have a buddy who is trying to decide between a Ford Courier and a Chevy Luv for a buildup and needs to find out. Thanks!
http://bp3.blogger.com/_RApJIlqIIM4/R8d ... C-042S.JPG
PostPosted: Mon Jan 01, 2007 2:34 pm
In the information section of the site there's basic measurements of the LUV that are common to all 72-80 models.
Tell your friend to go with the LUV because of the fact that the LUV has a larger engine bay and the frame itself is stronger than the Courior.
There's a reason why you'll find LUV trucks at the dragstrip and not too many Couriors. The frame alone is reason enough to opt for the LUV.
There isn't a Courior website that covers all kinds of ways to build a powerful performer AND a ton of site members that can give solid, positive advice.
Im not trying to bash the Courior, it's just that it's so much smoother to go with a LUV build. If one were to build a lowered custom or something else that would stay with a stock engine, then by all means do it!
But from a performance standpoint, the LUV has the capability to make it happen with alot less work.
PostPosted: Mon Jan 01, 2007 2:37 pm
http://www.luvtruck.com/PDF/LUV_Demension.pdf
Here you go...
Users browsing this forum: Bing [Bot] and 17 guests
