It is currently Sun Oct 19, 2025 12:25 am
 Post subject: Replacement dome light
PostPosted: Tue Mar 18, 2003 1:48 pm
Does anyone have a good idea on what to do for a dome light? My stock one is shot and i'd like to get a light in the truck somehow. The original light was the basic one that didn't use any door switches. It just had the on/off switch at the light itself. Any ideas?
PostPosted: Wed Mar 19, 2003 6:07 am
I installed a door switch. it is soooooooo easy.
I am running a dome light that I got off the shelf at the parts store.
03Cobra
PostPosted: Wed Mar 19, 2003 7:31 am
i've always wanted the door switches. mainly because my alarm would go off and that my back window does not lock :oops:
300, about damn time :oops: :drinking: :drinking: :drinking: :drinking:
 Post subject: dome light
PostPosted: Wed Mar 19, 2003 10:31 am
I used a light intended for a boat, it is a very nice chromed metal with a sealed push switch. It is also very bright. It is used to light the inside of a boat and it mounts on a flat surface. It is made by Attwood. I fashion two small J-hooks and mounted it on one of the crossbows in the headliner. it is about 4 inches in diameter. Works great! You could hook it up to door switches.
1980 4X4 LUV
PostPosted: Thu Apr 10, 2003 12:35 pm
go to a wreking yard and get one for a full sized chevy. They arent much bigger (the old ones, pre 85) and should work alright.
