It is currently Fri Mar 20, 2026 10:13 pm
 Post subject: Sunpro Gauges
PostPosted: Tue Dec 26, 2006 8:24 pm
Anyone know where the probe of a Sunpro heeat gauge connects to the 1.8 liter luv engine?
Just realized mine has never been connected.
FIAA: Color Guard
PostPosted: Wed Dec 27, 2006 4:05 pm
The only way is to remove the stock temp sender and install the probe there. You'll lose the use of stock temp gage this way.
Getting both the stock gage and the Sunpro gage to work would require a new fitting in the water jacket. It's not a good idea to try and "T" off the same fitting. Coolant needs to flow across the sensors to effectively give accurate readings. A "T" fitting of some kind would leave the sensors in a pocket of coolant.
The stock sender is near the thermostat so it is positioned to give the most accurate reading. Finding a place somewhere else on the motor will give lower temp reading.
You might consider removing the Sunpro temp gage and install another type of gage (volts, amps or oil press). Maybe swapping a gage with someone that could use a temp gage.
It looks like somebody ran into the same problem and elected to keep the stock system.
 Post subject: gauges
PostPosted: Thu Dec 28, 2006 5:20 am
Thanks
Will try to get the Sunpro working, as of now, the stock gauge isn't hooked up either.
FIAA: Color Guard
 Post subject: Temp sender
PostPosted: Sat Jan 06, 2007 5:24 pm
Well, I spent an hour or so trying to figure out where te stock temp sender is... the Haynes manual is worthless by the way :D
Does anyone have a picture of where the sender connects to the engine, or which section of the wiring harness itends with?
Thanks
FIAA: Color Guard
PostPosted: Sat Jan 06, 2007 10:29 pm
It is on the underside of the intake manifold, forward of the carb.
 Post subject: .
PostPosted: Sat Jan 06, 2007 10:49 pm
Thanks rondog, that's perfect.
It just so happens I'll be under there ripping out the EGR crap tomorrow.
FIAA: Color Guard
