It is currently Sat Jun 13, 2026 9:40 am
PostPosted: Wed Dec 20, 2006 5:15 pm
please in dire need of clutch pedal and cable also flywheel for a cable operated clutch.....the luv is my only vehicle i am 17 and in highschool and need your guys help i will pay good money for these parts so please help me if you got them please please please
thankyou
jeremy james :roll:
Arquing with me is like running in the special olympics, even if you win your still retarded.
PostPosted: Wed Dec 20, 2006 5:34 pm
Maybe these will help
http://cgi.ebay.com/ebaymotors/81-82-Ch ... dZViewItem
cable
http://cgi.ebay.com/ebaymotors/MANUAL-F ... dZViewItem
flywheel
Haven't found a pedal, I will keep looking.
PostPosted: Wed Dec 20, 2006 9:05 pm
Better jump on those as thats a darn goo price.
PostPosted: Wed Dec 20, 2006 9:58 pm
best I could find actually, 1st I found as well. ain't it funny how sometimes that works.
Sorry still haven't found a clutch pedal set up, maybe someone on here knows where one is or has one they can sell ya.
PostPosted: Wed Dec 20, 2006 10:24 pm
Wat do u mean by pedal the haul bracket?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Wed Dec 20, 2006 10:39 pm
just the clutch pedal and that flywheel says that its for a four wheel drive does that matter
PostPosted: Wed Dec 20, 2006 11:20 pm
So you need the bracket or the pedal itself?
No the flywheel should work with either or, a 4x4 or 2x4.
PM redluv he is parting out a luv and probably has the pedals you need.
http://forums.luvtruck.com/viewtopic.php?t=12177
PostPosted: Thu Dec 21, 2006 7:17 am
My son has everything you need since he is swapping his out. PM sent to ya. His ID on here is luvcrazyswaps. We are in Jeff City close also.
PostPosted: Thu Dec 21, 2006 10:07 pm
The only place you'll run into an issue on the flywheel is if it is for a 1980 4x4, or an 81 or newer. They put a bit larger clutch disc on those so the flywheel is slightly different. The one linked on ebay above appears to be for the 80 4x4 or 81-82.
If you plan to buy a clutch kit (pressure plate, disc, and etc) you could use that flywheel, just order the kit to match, like tell them it is for an 81 LUV. You would end up with a bigger better clutch.
PostPosted: Thu Dec 21, 2006 11:42 pm
Thanks for the heads up 800xl, and there you go sweetluvtruck. Have you found pedals?
PostPosted: Fri Dec 22, 2006 2:05 am
Well the bracket on these trucks suck mine broke took it out the bigest pain in the ass
79 4x4 1.8 liter
PostPosted: Fri Dec 22, 2006 12:04 pm
Did ya get it fixed yet?
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Dec 22, 2006 4:42 pm
well i still need a pedal and 800xl are you tellin me that the 81 pressure plate is bigger and so is the clutch and stuff.....i am ordering a clutch kit so should i get that one off ebay or what
PostPosted: Fri Dec 22, 2006 4:45 pm
ha all you luv guys if ;you have myspace send me a friend request okay its http://www.myspace.com/jjjhole luv masta i tried to add you but i dont know your last name....................anywho i need the clutch pedal with the hook up top for the cable clutch setup
PostPosted: Sat Dec 23, 2006 1:46 pm
I think you have it down. If you get a flywheel from an 81, get a clutch kit for an 81 and it should all work. Just make sure they match and you'll be fine.
PostPosted: Sat Dec 23, 2006 5:02 pm
Wats wrong with your pedal?
79 4x4 1.8 liter
PostPosted: Sat Dec 23, 2006 7:46 pm
its the one for a hydraulic clutch and i need a pedal for a cable clutch it has the hook up top that connects to the cable you know i need that really bad and got good money for it so help me get it..........
PostPosted: Sat Dec 23, 2006 8:01 pm
Well I actually may have one...Not sure though I had a lot of extra parts with my parts 4x4 truck. I can't remember if it had the pedals still in it or not. Since I will be in the neighborhood anyway tomorrow for christmas dinner with my parents I will check it out and see if it does.
 Post subject: pedal
PostPosted: Sun Dec 24, 2006 1:12 am
if your truck came with a hydraulic clutch situp stock, you will need more than just a clutch pedal
PostPosted: Sun Dec 24, 2006 6:52 am
dude my truck had a automatic okay.....i need the pedal still yet....i got a new cable the tranny ordered a flywheel and got a clutch kit......i have the works except for that dagum pedal........i need one badly still out my truck so let me no luvmasta if you got one please lol i got the money people but i need the parts lol
Users browsing this forum: No registered users and 55 guests
