It is currently Sat Jun 13, 2026 5:19 am
 Post subject: Leaking gas
PostPosted: Thu Nov 23, 2006 12:56 pm
My carberator is leaking gas. But it is leaking at the float chamber. I have tightened all the screws as tight as they can go but it still leaks. I had someone tell me that it was because of pressure inside the carb. If so how do I relieve that pressure.
PostPosted: Thu Nov 23, 2006 2:58 pm
A stock carb has a gasket around the float bowl cover. It may be the problem. You didn't mention if you have the stock Hitachi or an aftermarket Weber
PostPosted: Thu Nov 23, 2006 8:22 pm
It's a black rubber gasket that in the kit looks like a large "O" ring. There's a groove for it to fit into, and it's easy to replace. Watch out; there's a brass spacer on the shaft that the float bowl pivots on, and you better not lose it. It shouldn't fall out on it's own.
It's good to have the sight glass clean so you can check the fuel level in the float bowl.
These carburetors should not be soaked in acid bath; rather clean with a spray can or two of carb cleaner. They have a special finish that you lose with an acid bath.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Fri Nov 24, 2006 4:17 am
Just another theory, but you could have a clogged return line, the smaller hose hooked up to the carb. Pull it off and see if you can blow air back through it.
It still should not leak there, but that might be part of the problem. I would expect it to pour out the overflow tubes that hang out over each of the barrels of the carb if it was pressurizing the bowl. The needle valve should hold to. Sounds like you need the new gasket for the bowl cover plate either way, but you might check out some of the other parts that could be related.
 Post subject: 1.8 carb swaps
PostPosted: Tue Dec 19, 2006 5:32 am
does any one in here know if a asian carb off of a toyota will fit on a 1.8ltr love intake or does any one know if they make an adapter for it? Thanks for tha help
Cody
PostPosted: Tue Dec 19, 2006 10:30 am
You'll have to be a bit more descriptive. What brand of carb, what year and engine size Toyota motor.
 Post subject: carb swap
PostPosted: Wed Dec 20, 2006 12:14 am
its an 87 toyota with a 2.4litr 4cylinder with a 2barrell aisan an i wanted to try an swap it to my 1979 4x4 1.8ltr 4cylinder luv that has a 2barrell hitachi cus tha hitachi is screwed an i have an asian in tha bulding by tha way thanks fo tha reply
cody
PostPosted: Wed Dec 20, 2006 12:30 am
It seems that most would avoid trying to fit another type of conventional Japanese carb because of the electrical curcuit (run on solenoid, coasting richer). Not knowing the details of the Toyota carb and what kind of circuits it may have. An adapter plate may not be reasonably made to fit. And the linkage could be totally reverse to each other.
Most would take the time proven plan of installing a Weber 32/36 DG series carb. Everone will tell you that the Weber is the hot setup for a stock or modified LUV 1.8 engine.
Users browsing this forum: Bing [Bot] and 25 guests
