It is currently Sat Jun 13, 2026 5:20 am
PostPosted: Mon Dec 11, 2006 11:06 pm
ok i am driving my sweet luv and it just die's and it is not the gas i have good gas and good spark i think it is electrical all help will be helpful thinks to all
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Dec 11, 2006 11:29 pm
If you're getting good spark, it's not electrical. Is the fuel pump working?
Did it die while you were cruising down the road or sitting at a stop? Were you slowing down to stop and it died?
You'll need to go into more detail on what happened.
PostPosted: Mon Dec 11, 2006 11:33 pm
sorry man '
Sounds like my sons and we still haven’t found out yet... good gas flow good spark. was going down the road and it died.. He gets out of the field soon and we will try something’s if we find out what it is ill let you know.
PostPosted: Tue Dec 12, 2006 9:18 am
sorry my luv did the same thing and i have not found out what is wrong with it
PostPosted: Tue Dec 12, 2006 5:48 pm
I had a similar thing happen to mine. It turned out to be a loose wire at the fuse box. I Wiggled them around and it fired up, good luck
PostPosted: Tue Dec 12, 2006 7:50 pm
My uncle's did that, and he said that it was a fuse to the alternator. Replaced the fuse, and it fired right up.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Tue Dec 12, 2006 8:24 pm
thanks to all i will start working on wed on it and will try that stuff out and if i get it i will post what i find
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Dec 27, 2006 12:06 am
wow....
i am really glad that u posted this cause the Luv that i am driving sounds like it has the same prob
the guy said"I was driving it one day and it just died"
so check connections and fuses then replace the relay if first 2 don't work?
kinda sounds like a common prob in the Luvs...
PostPosted: Wed Dec 27, 2006 12:35 pm
Could it be an alien spaceship beaming down? Maybe they wish they had a LUV. :rocol:
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Dec 27, 2006 2:06 pm
Or maybe its just a curse..... :(
PostPosted: Mon Jan 01, 2007 3:42 pm
Ok like I said same thing happened to my son and we found the problem today..... Broke the cam... The pin that goes to the sprocket busted so the chain and sprocket turn but not the cam 8O :roll:
PostPosted: Tue Jan 02, 2007 8:06 am
Ouch
Users browsing this forum: Bing [Bot] and 17 guests
