It is currently Mon May 25, 2026 5:32 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Nov 16, 2006 11:24 pm
nvm my last post i figured it out, and it looks really good lowered, but i think im going to alittle further, and cut the bump stops alittle bit get a little more out of it.
thanks for all your help everyone
PostPosted: Fri Nov 17, 2006 12:13 am
it sould look good any pics
Im luvin it
PostPosted: Fri Nov 17, 2006 12:28 am
81Luvsparks if you were losening the bars that are connected up front you might have to get your front end re-aligned. Those bars up front are called strut bars and they adjust your caster angle.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Nov 17, 2006 6:00 pm
i will have a pic up soon, just got to cut the bump stops alittle. so ill have one when i first got it, and one lowered with out cut bump stops, then one with
PostPosted: Fri Nov 17, 2006 6:02 pm
http://smg.photobucket.com/albums/v358/ ... 6/Car/luv/
here are some of when i got it
PostPosted: Tue Nov 21, 2006 5:05 am
I dont think he is touching them. Strut bars or another common name is castor rods.
Thats probably nearly too low. The torsion bars will be as soft as buggery and you wont have any suspension travel. Being that soft and low just turning a corner will create enough body roll to bottom the suspension out.
Bob.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 25 guests
