It is currently Sun Dec 21, 2025 6:20 pm
PostPosted: Thu Apr 20, 2006 5:22 pm
Found some rust through in floor on both sides and a little starting to rot up the kick panel.interior rocker. anyideas on fixing this area or suggestions? diamond plate bed getting cut off in the morning. rom underside where it bolts down cant get to the top of bolt they welded over them. Help me out guys I want to make it work. thanks
PostPosted: Fri Apr 21, 2006 10:31 am
I had the same problem I took care of the rust and layed some fiberglass on both sides of the area it worked great. plus BE SURE TO PLUG UP HOLES OR CHECK FOR HOLES IN THE FIREWALL SOMETIMES THE CAUSE OF RUST!!!!
PostPosted: Fri Apr 21, 2006 10:53 am
I was able to cut out the offending piece and replace it with new metal with a flux core mig.
PostPosted: Fri Apr 21, 2006 11:01 am
sweet anybody else have some ideas need to patch up on the side a bit by were the bottom of the door closes on the inside.
PostPosted: Fri Apr 21, 2006 1:26 pm
keep in mind that fiberglass is not water proof. i have built and repaired boats too many years not to know this is true. what keeps the water out is howw well it is coated. bare resin WILL absorb water.
PostPosted: Fri Apr 21, 2006 11:42 pm
Thats too bad for old Mr. Rust I used fiberglass and Cold Cat :smt093 AAAARGGG!!!!!
PostPosted: Sat Apr 22, 2006 6:06 am
didn't say it wont work, it just has to be coated with something that is waterproof.
PostPosted: Sat Apr 22, 2006 7:34 am
I would prefer metal doing ground up would like the repairs to last and look good. I was told that a mig weld- wire feed. would not hold I do have a few places to repair not sure if its worth buying and learning or paying someone to do the job. Any ideas on cost to buy and what or what people charge.
PostPosted: Sat Apr 22, 2006 11:27 am
I had one bad spot on the drivers side. I cut out a square hole. then took a piece of sheet metal and ribbeted to the floor. Then I sanded the whole floor and painted on some Por-15. Since I was covering the entires floor with a vinyl mat, I figured you aren't going to see the patch job.
PostPosted: Sat Apr 29, 2006 9:35 am
ditto...I did the same as Zane except mine was on the passenger side....it all looks pretty good though...:)
PostPosted: Thu May 04, 2006 6:25 pm
you were told a mig weld wire feed wouldnt hold? I can tell you that is a load of crap right there. I use a miller 175 with .023 wire and gas for all my body work. Most good repair shops use the same thing. Get some scrap tin from the metal yard and use a mig with gas. Dont use flux core, you have to heat the metal up too hot to get the core to melt and that ends up warping your panels (even if it is on the inside).
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Fri Aug 25, 2006 10:18 pm
I had some rust areas on the floor boards (drive/passenger sides) I patched them w/new sheetmetal and brasined welded it. After that I sprayed primer over it, seamed sealed around the weld, then undercoated it. Worked out awesome!
PostPosted: Wed Oct 25, 2006 5:20 pm
I did mine with POR-15. Wow, I did the whole floor with it, and patched up a couple holes on the passenger side. It looks real good. I'm waiting on the liner from RockAuto, and then I will put my mats down, so that's that!
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Thu Oct 26, 2006 4:49 am
Not to mention that flux core stuff splutters like billyo.
PostPosted: Thu Oct 26, 2006 5:26 am
Bob, not making sport of you, I like those local sayings. But seriously, what is a billyo? I know I can't be the one inquiring mind.
PostPosted: Thu Oct 26, 2006 5:52 am
Billy-Ohh
Means a long way away.
Or
Goes on and on and on.
