It is currently Mon Jun 08, 2026 8:29 am
PostPosted: Fri Sep 29, 2006 3:18 pm
I need a front timing chain cover since the timing chain broke and put a hole in it. I took the valve covers off and found the timing gear with several broken teeth, and the cam gear was the same way. The timing chain looked like it went through a war - the fellow who had it before said the oil pump went out - but that wasn't the problem.
So now if I get those parts, I can get my newly acquired 81 4x4 on the road. And alarmingly, this had AC and there was only surface rust on it.
HELP!
8O
PostPosted: Wed Oct 04, 2006 1:53 pm
No one has an engine they are throwing away and has a timing chain front cover? :roll:
PostPosted: Wed Oct 04, 2006 1:58 pm
I might have one in a couple of weeks. If you still need it then, let me know.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Wed Oct 04, 2006 3:00 pm
Banishment Pending
Check the classified and auction sections of this website, and as always there's E-bay to find what you need.
PostPosted: Thu Oct 05, 2006 8:26 am
I checked eBay and other sites and nope- nuttin. So I am stuck with the largest site of LUV around.
Yeah - I'm gonna need it. It is one of those things where I have a choice between a $1500 engine or a cheep timing chain cover.
I'll take the timing chain cover Alex!
PostPosted: Thu Oct 05, 2006 9:12 am
pm sent
Users browsing this forum: Bing [Bot] and 17 guests
