It is currently Wed Jul 01, 2026 4:24 pm
 Post subject: swapping valve springs
PostPosted: Thu Mar 27, 2003 1:36 pm
If a fella were going to upgrade the cam and valve springs on a s.b., could it be done w/o removing the heads?
 Post subject: Seen It Done
PostPosted: Thu Mar 27, 2003 3:22 pm
bighappy,
I've seen it done by doing a cylinder at a time. You screw and air fitting into the spark plug hole and keep positive pressure on the cylinder. Something around 75 PSI should do. Then you compress your valve springs as usual and swapping out you springs.
 Post subject: valve springs
PostPosted: Thu Mar 27, 2003 7:05 pm
Yes, i have done this. Remember though to bring your piston to TDC before trying to remove the spring. Good luck, Bryan
PostPosted: Thu Mar 27, 2003 7:54 pm
if your worried about your springs, you must be puttin a healthy cam in , HUH?!?
give us the profile _____________ .
oh yeah, and another yes. just get out the ben-gay for your back. I keep some in the glove box :lol:
PostPosted: Thu Mar 27, 2003 9:30 pm
Im not stuffing a huge cam in it, just something along the line of 470/480-220/240. Just dont want a 30 year old spring breaking on me. Thanks for the help.
PostPosted: Fri Mar 28, 2003 6:32 am
yeah plug the air in it.... works just fine.
03Cobra
